Oil change
Started by TheTigerUK, May 9, 2022, 21:27
TheTigerUK
Do all the under engine covers need to be removed to do an oil change ?
Thanks, I should of looked last time I was under.
Front one.
TheTigerUK
Quote from: Gaz mr-s on May  9, 2022, 21:32Front one.
ps: Are the magnetic sump plugs worth fitting ? M12 x 1.25 ?
Quote from: TheTigerUK on May  9, 2022, 22:06Thanks
If you are going to fit one, dont get a cheap one as the threads can strip.
You can get small magnets off ebay and pop one on the outside of the standard sump plug.
McMr2
Quote from: TheTigerUK on May  9, 2022, 21:27Do all the under engine covers need to be removed to do an oil change ?
Unless you have a proper lift, taking off the rear driver side wheel helps with access too.
2004 Silver. Stock(ish).
TheTigerUK
Quote from: McMr2 on May  9, 2022, 22:21Unless you have a proper lift, taking off the rear driver side wheel helps with access too.
Quote from: Topdownman on May  9, 2022, 22:14If you are going to fit one, dont get a cheap one as the threads can strip.
Have a look at Oil Filter Magnets, Motion Pro is one named supplier but they are on eBay from £1.99.
Not sure if sump plugs or oil filter magnets come with a chromium finish though John,  so best replace the engine under covers!
Quote from: Topdownman on May  9, 2022, 22:14You can get small magnets off ebay and pop one on the outside of the standard sump plug.
Which is what I have done. To date. Nothing on sump plug. Which is good.
@TheTigerUK
Your ramps will give you more than enough clearance.
Makes me smile. A trap door for the sump plug. But still need to remove nappy for filter access.
Quote from: Joesson on May  9, 2022, 22:38You can get small magnets off ebay and pop one on the outside of the standard sump plug.
I took that tip some years ago with a roll of dime sized neodymium magnets. Two on top of eachother and fingers crossed they don´t attract the shims from under the valve tappets  ;)   Their magnetic attraction is about a thousand times their own weight.
Do take care removing them as they material us véry brittle. Hence best a roll  ;D
Quote from: Ardent on May  9, 2022, 23:01@TheTigerUK
I may be cynical but having had my car "serviced" by my local Mr T on four occasions, I would observe that there is little visual evidence of the removal of the filter, whereas the cleanliness of the oil is evident from the dipstick.
Quote from: Petrus on May 10, 2022, 08:35I took that tip some years ago with a roll of dime sized neodymium magnets. Two on top of eachother and fingers crossed they don´t attract the shims from under the valve tappets  ;)
Can't claim the quote about EBay magnets on the sump plug, that was from @Topdownman. My offering was Oil Filter Magnets, that has received no comment.
TheTigerUK
After fitting one to the outside of the plug have you ever tested it to see if the magnetic force goes through the plug ?
Quote from: TheTigerUK on May 10, 2022, 08:56After fitting one to the outside of the plug have you ever tested it to see if the magnetic force goes through the plug ?
I have a gold plug one on the V6 and will put a magnet on the new car. I have a magnet on the motorbike but that is still being serviced by the dealer so dont know if there was any debris collected on the plug.
Yes.
On my motorbike it does not work as the sump ´plug´ is the bronze cap of the gauze filter.
I tend to recall.
@Carolyn attaches her magnet to the inside end of the sump plug.
