76mm (3”) reduction to 2.5” for exhaust?
Started by jvanzyl, May 16, 2022, 22:57
So my turbo has a 3" v-band for the outlet.. current exhaust is 2.25"
I'm assuming the best thing is to run 3" continuously from the turbo outlet, through the cat and into the Muffler? And not to reduce it any where etc?
Depends on the size of the turbo, amongst other factors.
Yours is a simple question, but the answer cannot be such.
Gaz2405
Having just rigged up a 3" on mine for testing it was bloody loud!
Gone straight back to 2.5"
Out of curiosity have you actually measured the size of the opening? The 3 inch could refer to the size of the clamp, it might be a 2.5 inch opening.
Quote from: Gaz2405 on May 16, 2022, 23:45Having just rigged up a 3" on mine for testing it was bloody loud!
interesting - good to note!
Quote from: Call the midlife! on May 17, 2022, 06:41Out of curiosity have you actually measured the size of the opening? The 3 inch could refer to the size of the clamp, it might be a 2.5 inch opening.
right - I'll need to do that.. could be a big deal over nothing!
