Heater fan issues
Started by Mark A, June 27, 2022, 16:30
Mark A
I was asked to look at a friend Roadster which has an intermittent heater fan issue this weekend.
I checked and replaced the control unit
Pulled the fan motor out and connected to a 12v supply works fine
I can hear the solenoid clicking when switching on the fan controller
The current from the solenoid seems to be lower than I was expecting, so changing the solenoid behind the glove box
All the wiring looks intact and no other systems appear affected
I'm going to have another look later this week, I was think of bypassing the solenoid with a patch cable, any other suggestions or experiences of faulty heater fans?
What is the actual issue? It's not clear.
Mark A
Sorry, the fan does not run or will work for a little time then stop.
Quote from: Mark A on June 27, 2022, 23:03Sorry, the fan does not run or will work for a little time then stop.
Have you ruled out the switch?
Easy to swap over a known working unit.
Mark A
Yep changed the hvac unit over and no different
Think you'll need to test the circuit with a multimeter.
