Vin and Engine number
Started by alancdavis, September 23, 2022, 12:13
alancdavis
Hi  Can anyone tell me where to find the Vin and engine number
Red Calipers with DBA Cross Drilled and Grooved Discs,,,,2005 Red and Black Leather Custom Seats,,,,,TSW,17ins Wheels,,,,,2003 colour coded side vents and rear bumoer inserts,,,,Custom rear bumper skirt,,,TTE Twin Rear Pipes,,,,,,TTE Front Bumper,,,,,Red and Black Steering Wheel,,,,,Blitz Induction Kit,,,,,TTE Style Bar,,,,,Goodridge Stainless Braided Hoses,,,,,,,,,Front and Rear Strut Braces,,,,,,Rear spoiler
V5
Depends on age
Vin
Plate above batt, or door pillar
Or between wipers.
En number not easy to see. Left end of engine as you look at it.
The engine number is on the end of the cylinder head, (to your left as Ardent says) on a small flat area just below the cam cover.  It is stamped in vertically.  It's a pig to get a decent look at it.  A mirror helps - so long as you can make sense of the reversed image.
alancdavis
Thank You Gents for the info
Quote from: alancdavis on September 23, 2022, 17:38Thank You Gents for the info
Gent and Gentess  ;)
Or more accurately in this case.
Muppett and rocket scientist.
LeEdFollow
Just curious... when did Toyota stop riveting VIN plates into the engine bay on the roadsters?
Did a google image search and looked on ebay/autotrader. I noticed that every pre-facelift car I've seen has a VIN plate in the engine bay but most later facelift cars do not. I know that the VIN moved to a sticker in the door opening, so it doesn't matter. Just curious.
My 2014 GT86, 2017 Aygo and 2020 Corolla have VIN stickers in the door openings instead of plates and so does my recently acquired 2005 MR2. So I'm guessing it was around 2003/2004 ish time Toyota moved from plates to stickers?
Searched the forums and the web but found no details on exactly when the switch occurred.
SV-3
Quote from: LeEdFollow on January  2, 2023, 11:09Just curious... when did Toyota stop riveting VIN plates into the engine bay on the roadsters?
2003 FL: VIN plate in engine bay.
Eclectic - not electric
Sony WX-920BT
"Hardtop Cognoscenti"
"Stock Cubed"
"AirCon Aficionado"
"Keeper of the Beeper"
@LeEdFollow
Probably around the PFL/FL change 2004? ish.
05 and no plate. I like the plate above the bat. Japanese writing etc. Just seems fitting.
Quote from: Ardent on January  2, 2023, 21:2405 and no plate. I like the plate above the bat. Japanese writing etc. Just seems fitting.
Mine does have the rivited aluminium but no Kanji signs.
My PFL has the VIN stamped on the front bulkhead. Just remove the plastic cover to view.
