Front Speaker Upgrades
Started by Gibla, October 1, 2022, 08:48
Gibla
I'm sure this topic has been done to death in years gone by, but maybe my question isn't fully addressed in those posts.
I am looking to spend a max of £150 on either new or second-hand units.
Could folks suggest Manufacturers + even better a specific product they make, that would be a significant improvement over stock?
This will be powered by a JVC KW-DB93BT Double DIN CD Receiver with Digital Radio (DAB+) < originally a modestly costly unit, but now a  reinstallation from one of the cars I have recently sold.
ok for at least 50% of the time I would far prefer to listen to the engine, but a reasonable sound system does add much to the pleasure derived from the car (especially if doing circa 8-10k miles pa)
I plan to use Kilmat sound deadening 'stuff' to aid the effectiveness of the speaker upgrades https://kilmat.com/
2001 Dark Green MR-S (6R4)
Gibla
^^ Maybe a modest budget, but I cannot justify spending mega money, as my hearing is far from perfect (a combo of old-age and a period of time in my life in an incredibly noisy environment)
puma2
:) try focal many have :)  :)
Gibla
Good call @puma2
I had dug out these on Fb previously that are Focals but unsure if they would fit
Focal Access 130AC 13cm 5.25" 2 Way Coaxial Car Speakers 100w inc grills
Could *anyone* out there tell me if these would fit ???
s12vea
16cm door speakers fit. I've fitted focals in mine and soundproofed doors and I have to say amazing sound. I also used vibe 60.4 amp and I would say it's hard to beat
Ex TTE Turbo
Another one won't hurt  .....
Gibla
Quote from: s12vea on October  1, 2022, 09:5916cm door speakers fit. I've fitted focals in mine and soundproofed doors and I have to say amazing sound. I also used vibe 60.4 amp and I would say it's hard to beat
Cheers sir
Just located these for a decent price, << Focal PC165 6.5" coaxial speakers 16.5cm
or these
Vibe Black Air 6.5" Component Speakers
s12vea
Quote from: Gibla on October  1, 2022, 10:05Cheers sir
or these
I've had both in the past and focal have much better sound quality
Ex TTE Turbo
Gibla
You did well. The most important thing with speakers especially if you run it without an external amp is its sensitivity otherwise they can sound lifeless.
91.3 dB is good.
 If you want to get the best out of them get a small external amp with 50 watts X2 RMS and let them sing. Its not about being louder it will sound tremendously better even at lower volumes.
Gibla
Quote from: Dev on October  2, 2022, 21:33You did well. The most important thing with speakers especially if you run it without an external amp is its sensitivity otherwise they can sound lifeless.
91.3 dB is good.
This seems to fit the bill well .....Alpine BBX-T600 Amplifier 2 Channel Class AB Bridgeable Stereo Car Amp 140w RMS < this fits in with your suggested spec ie 50 watts x2 RMS
Fitting kit? https://www.dynamicsounds.co.uk/stinger-ssk8-8ga-600w-complete-wiring-kit.html
Would that just about do it?
Alpine makes reliable amps. It should work well in that system at its price point to get the most value out of your upgrade. Just make sure to set the gains correctly to maximize the sound output even if you listen at a lower volume. No need to spend a lot in RCA cables but get ones that are quality as far as being made durable for an automobile environment.  That fitting kit should be fine. Stinger makes quality stuff.
 It should sound nice. I also have a JVC unit KW-M855BW that I like but wished it had a parametric EQ.
s12vea
https://www.carelectronicsnottingham.co.uk/vibe-powerbox-654m-amp-compact-micro-class-d-4-channel-car-stereo-amplifier?gclid=Cj0KCQjwkOqZBhDNARIsAACsbfKy-8tfZ0Mpih4m8Pe3uE1orm1zJrBoV1Td1BktnZyJybSFkm4mEWMaAhg8EALw_wcB
I've used this amp for a number of year it plugs in between iso connection on back of headunit and really adds some power to the front speakers and not additional / separate wiring compared to adding a traditional amp
Ex TTE Turbo
Quote from: s12vea on October  3, 2022, 08:43https://www.carelectronicsnottingham.co.uk/vibe-powerbox-654m-amp-compact-micro-class-d-4-channel-car-stereo-amplifier?gclid=Cj0KCQjwkOqZBhDNARIsAACsbfKy-8tfZ0Mpih4m8Pe3uE1orm1zJrBoV1Td1BktnZyJybSFkm4mEWMaAhg8EALw_wcB
That should be a good amp. I have a Vibe Lightbox GH class amp.
 I would personally run a separate power and ground for this amp even with its class D design considering the wiring harness used in our cars is puny and is probably degraded with age. It probably works better with newer cars as they have thicker gauge wiring for its harness for OEM double din NAV units.
