Odd brake pad wear
Started by Padge, January 9, 2023, 14:28
Padge
Afternoon all,
Wondering if anyone has seen this before/got any ideas please. EBC Yellowstuff pads which have been used on track. On both sides at the rear, the outboard pad is sitting slightly proud of the disk, and has worn a large lip which has in turn caused that pad to not make full contact with the disk (you can just about see in pictures a rust ring on the disk). The inboard pad on both sides is perfectly fine.
I didn't notice it sitting proud of the disk when installing but probably didn't even look. When replacing the pads I also replaced the hardware/shims that sit in the carrier.
Is this an installation error (if so what?) or a manufacturing defect with the pads?
Have you checked your calipers to see if they are sticking?
Padge
They didn't seem to be sticking no, but I wouldn't have thought the calipers are even in play here are they? Even with the calipers off the pad is sitting above the disk
The pads are too big or the discs are too small.
Maybe front discs on the rear (fronts are slightly smaller)
EBC Yellowstuff pads are often mentioned on here. I recall only comments concerning wear rates, not dimensional inaccuracies.
That the inner pad is within the circumference of the disc suggests that there is some misalignment with the installation of the outer pad.
You mention replacing the hardware/ shims, perhaps that is the cause of the concern as the shims are not unlike those puzzles sometimes seen in Christmas crackers and it would not be too difficult to get them not quite right.
I suggest that you file the lip off the pad/s, also use the file, gently, on the location groove at the ends of the pad to ensure the pad is sitting correctly in the caliper. Check the installation / arrangement of the shims with the knowledge that the pad has been too high previously.
PS just seen @Carolyn 'S comment about relative size of the disc/ pad and that certainly could be the case! My comments may apply but only if the pad/ disc sizes are correct.But, My pads are inside the disc circumference!
PS
Reference to comment concerning disc dimensions and with ref. to  Europarts Eicher discs,
Rear Disc 263mm diameter x 15mm thick.
Front disc 255mm diameter x 18mm thick.
Something quick and easy to check.
Padge
Apologies my phone camera isn't the best, here's some pics of the disc
Looks like the difference between front and rear discs is 6mm - the lip on the pad is tiny, far smaller than 6mm so doubt that would be it, also because the inboard pad is perfectly fine.
From Joesson's post I am going to double check the hardware in a bit, I'm wondering if the "spring" for the outboard pad is pushing the wrong way (ie towards edge of disc rather than centre) I'll update when I go nad have a look.
MRSwede
Should the pad wear indicator plate not be on the inside ? And its a little bit hard to see, aren't the support plates mounted upside down (wrong way around)
Padge
Quote from: Anon on January  9, 2023, 18:02That disk is f***ed and will destroy any new pad you put at them.
How so? What looks on the picture like cracks/pitting is just from a splash of isopropyl. I've not measured them but wondering what makes you so sure
Quote from: MRSwede on January  9, 2023, 20:42Should the pad wear indicator plate not be on the inside ? And its a little bit hard to see, aren't the support plates mounted upside down (wrong way around)
Usually yes but the in and outboard pads have different "ears" on them and can't go on any other way so the wear indicator has to go that side. RE the support plates yes good spot I believe that is the issue, haven't had chance go out again as of yet
MRSwede
Meaning that the indicator should be mounted on the inside pointing down.
Padge
Do you replace your discs after the cars been sat for a couple weeks and they get rusty then too?
I'll definitely keep an eye on it and appreciate the response but I think replacing the disc just because of that is a little premature
Padge
Quote from: Padge on January  9, 2023, 23:45Do you replace your discs after the cars been sat for a couple weeks in the rain and they get rusty?
+1
That's too far gone.
Quote from: Padge on January  9, 2023, 23:45Do you replace your discs after the cars been sat for a couple weeks and they get rusty then too?
If the disc has any sort of lips on the rusted outer parts then the new pads will just contact on these outers rusted parts of the discs, therefore ruining your new pads. If the disc has no lips then just use a wire brush attachment on a drill and bring them back to polished metal and you'll be fine.
Padge
To update, the pad issue was indeed the shim/hardware in the carrier being the wrong way round
Been for a test drive and discs are nice and shiny throughout, no lips. Appreciate the concern though
Quote from: Padge on January 10, 2023, 13:17To update, the pad issue was indeed the shim/hardware in the carrier being the wrong way round
Solution suggested post #5 in 1 hour 20 minutes.
Must be quicker than waiting for an ambulance!
