Apexi power FC question
Started by JB21, February 13, 2023, 13:25
Quick one.
I'm presuming the Apexi power FC serial number ZT231 020 *** will run any 2ZZ engine with cable throttle?
I ask as my 2zz conversion uses 2 ECU's. OE MR2 ECU to control body and dash functions such as revs, some dash lights, coolant fan etc, and a Corolla 2ZZ ECU just controlling engine parameters.
Presume I can just plug and play the Apexi FC in place of the Corolla ECU?
Gaz2405
That's my understanding of it.
AJRFulton
Would you be looking to buy one?
Mine may be up for sale very soon and well if.... I found somebody wanting to buy it may force my decision to go ecumaster. It works with a cable throttle.
Can be confirmed working by Andy @JSpec too.
Quote from: AJRFulton on February 13, 2023, 16:08Would you be looking to buy one?
How much mate?
AJRFulton
Quote from: JB21 on February 13, 2023, 19:25How much mate?
Never really thought about it. It has an FC controller too, but the screen has a few lines of pixels out - still usable, but not perfect. It's reset to default map as well.
What sort of price do these sell for? I'd need to look, but just about to take off from Riga to Edinburgh.
I just want to upgrade to the ecumaster black
Quote from: JB21 on February 13, 2023, 13:25Quick one.
Out of curiosity, why didn't you just use a Celica 190 ECU instead of two ECUs?
Quote from: Alex Knight on February 14, 2023, 23:13Out of curiosity, why didn't you just use a Celica 190 ECU instead of two ECUs?
Dunno, its how Rogue set it up with the build.
Gaz2405
Give me a shout if you need any of the software for datalogit etc
Quote from: JB21 on February 15, 2023, 08:54Dunno, its how Rogue set it up with the build.
That's bloody odd.
You can just re-pin about 8 wires (probably less in your case) get a 190/T-Sport ECU and ditch both the ones you have now to save a bit of weight?
Quote from: Alex Knight on February 15, 2023, 23:32That's bloody odd.
CBA to save a few hundred grams, got bigger things to worry about ATM i.e pulling the gearbox. Plus my JDM ECU wouldn't work.
