What is the washer jet plug
Started by AJRFulton, April 2, 2023, 11:11
AJRFulton
I have a third party washer bottle on car.
What does the washer bottle plug look like?
The black cap on the white neck coming from under the rear of the head lamp unit:
That's one item that is on the same side with LH or RH drive cars.
AJRFulton
Sorry typing from workshop.
I mean the plug to work the motor. I need to cut it to drive my one off the stalk.
Having difficulty knowing what is what.
I have some wiring diagrams that might help.
Let me know if you want them
Quote from: AJRFulton on April  2, 2023, 20:22Sorry typing from workshop.
You can actually see it in one of Petrus' photos, connects directly to the top of the motor mounted on the side of the reservoir.
Quote from: Call the midlife! on April  2, 2023, 23:01You can actually see it in one of Petrus' photos, connects directly to the top of the motor mounted on the side of the reservoir.
I used it when replacing the OEM one with a lightweight bladder a bit further back. Placed the photo several times before. Should be easy to find.
