Header gaskets
Started by Nvy, April 25, 2023, 05:47
Nvy
So I decided to wait until I move house to turbo my two. So now I am looking for gaskets to bolt everything back together. Have toyo, topspeed catless pipe and oem muffler, any recommendations?
Tried but seems that I cant find them anywhere.
I believe OEM is the way to go.
Especially the head to toyo gasket.
Quote from: Ardent on April 25, 2023, 08:43I believe OEM is the way to go.
Even more important are OEM crush rings for the other end of the manifold.  TCB will have them.
I have genuine Toyota & an Erling manifold gasket & they seem identical other than the 'rivet' holding the two layers together.
Nvy
The problematic gasket is topspeed pipe to oem muffler. I think its a custom job or we can find them somewhere?
That's a composite doughnut on the stock exhaust, I would expect it's the same for your set-up as you are using a stock muffler.
Again, TCB will have them.
'donut gasket' into ebay.
Nvy
https://www.monkeywrenchracing.com/product/top-speed-che-downpipe-mr2-spyder-00-05-stainless-with-cat/
Not quite the same, it doesnt go into the muffler and its not with springs where the bolts are.
Quote from: Nvy on April 25, 2023, 10:31The problematic gasket is topspeed pipe to oem muffler. I think its a custom job or we can find them somewhere?
I had the same issue with mine. The solution is to weld a small pipe to the end of the flange to hold in the doughnut gasket similar to the OEM. The gaskets that are provided with the down pipe are garbage and leak badly.
Even the one on the other side that connects to the header burns out and then leaks. The solution there was to use a specialized gasket called a Remflex.
Quote from: Dev on April 25, 2023, 18:15I had the same issue with mine. The solution is to weld a small pipe to the end of the flange to hold in the doughnut gasket similar to the OEM. The gaskets that are provided with the down pipe are garbage and leak badly.
Even the one on the other side that connects to the header burns out and then leaks. The solution there was to use a specialized gasket called a Rimflex.
Remflex?   Header to cat?  Can you post a link to what you used. (if we can get it here...?)
Sure. If you have to import it, its worth it. I tried other speciality gaskets and they blew out in time.
What makes this gasket unique is it is made of very high temp graphite which does not blow out and as the gasket crushes it seals any irregularities on the flange.
The important thing here is to follow directions and use it at the specified torque otherwise if you crush it flat it will be no good.
 I bought the sheet and traced out the shape using the old gasket. I have been leak free for over four years.
https://www.amazon.com/Remflex-GS16511-Gasket-Sheet/dp/B006G30D6Q/ref=sr_1_7?crid=297NIOH5SKBQ6&keywords=rimflex%22exhaust+gasket&qid=1682444070&sprefix=rimflex+%2Caps%2C61&sr=8-7
£28.72 on Amazon for a sheet.   ::)
Sheet metal shears, chisels and hole punches.
#14 & #15 above remind me of a song that has been around for a long time!
Oh, and a band saw ('cos we've got one).
Quote from: Carolyn on April 26, 2023, 08:49Oh, and a band saw ('cos we've got one).
I read the ad' afterwards.... 'stanly knife or craft knife' they say..... optimistic?
Quote from: Gaz mr-s on April 26, 2023, 09:56I read the ad' afterwards.... 'stanly knife or craft knife' they say..... optimistic?
No but you'll need a good supply of blades.  Work on an old plank of timber.
Quote from: Carolyn on April 26, 2023, 10:41No but you'll need a good supply of blades.  Work on an old plank of timber.
A cheap pair of tin snips would do the job surely.
Quote from: 1979scotte on April 26, 2023, 12:05A cheap pair of tin snips would do the job surely.
Not when cutting the holes.
Is that different to a Stanley knife?
Quote from: Ardent on April 26, 2023, 16:58Is that different to a Stanley knife?
Yeah.... a misspelled one....
