Front arms and associated bits
Started by MrChris, April 30, 2023, 10:38
MrChris
After my "slight mishap" on Wednesday at Mallory park I've managed to get the 2 up on stilts to assess the damage. Pictures are below.
I think I need:
Front arms: are something like these still recommended? eBay Yaris arms
Drop links
And I think that's it? Anything I'm missing?
Those will do the job.
While you've got them out, take the chance to clean, de-rust, treat and paint the inner mounting brackets.  That front subframe needs a bit of TLC before it's too far gone.
A trick with the vertical bolt, is to undo it a bit at a time, knocking the a-arm back up the bolt as you go.  Plenty of Plus-Gas !!
Well done, by the way.  It shows you were trying.
MrChris
Thank you @Carolyn - I've treated the sub frame last year but the winter hasn't been kind it seems. I'll get some rust converter ordered up, I've already got the other bits.
And yes, I was trying a bit too hard!
Quote from: MrChris on April 30, 2023, 12:04Thank you @Carolyn - I've treated the sub frame last year but the winter hasn't been kind it seems. I'll get some rust converter ordered up, I've already got the other bits.
I meant knocking the A-arm up not the sub-frame. (God knows what I was thinking when I wrote that.)
MrChris
Created new topic.
