Clutch for 1ZZ turbo
Started by jvanzyl, May 9, 2023, 17:56
Hi all,
Any recommendations for a nice street friendly clutch for a 1ZZ turbo?
Will be set to roughly 200whp (no idea on torque values but assuming under 250lbs).
John
Gaz2405
I Managed on a fresh 2zz compressor item.
This will see you right.
Really great, reliable product from a professional company:
https://clutchmasters.com/i-30500058-fx200.html
Quote from: Gaz2405 on May  9, 2023, 18:53I Managed on a fresh 2zz compressor item.
Awesome thank you
Quote from: Alex Knight on May  9, 2023, 18:54This will see you right.
Thank you- I can only guess that the holding values are correct? I can't seem to see any actual numbers!
s12vea
Works a treat and keeps the standard clutch pedal feel
Ex TTE Turbo
Another one won't hurt  .....
Quote from: jvanzyl on May  9, 2023, 21:22Thank you- I can only guess that the holding values are correct? I can't seem to see any actual numbers!
Rated at 335 ft/lbs of torque.
Happy with a stock LUK
Whoa- might be over kill for me. Thanks though! I'll check the prices of the 2zz compressor
Quote from: Alex Knight on May  9, 2023, 21:34Rated at 335 ft/lbs of torque.
Quote from: s12vea on May  9, 2023, 21:28Works a treat and keeps the standard clutch pedal feel
I shall investigate this one.
s12vea
Quote from: jvanzyl on May 11, 2023, 19:30I shall investigate this one.
I've used the Luk and Exedy on two different roadsters one circa 200bhp and one circa 240bhp both ideal match
Ex TTE Turbo
Quote from: s12vea on May 11, 2023, 20:16I've used the Luk and Exedy on two different roadsters one circa 200bhp and one circa 240bhp both ideal match
Where do you get them from? I've been looking on the usual sites and they so far haven't differentiated (from what I can tell) between stock 1zz and 2zz comp?
Gaz2405
I used AtoZ motor spares, just googled a corrolla compressor for a reg no.
Quote from: Gaz2405 on May 11, 2023, 21:04I used AtoZ motor spares, just googled a corrolla compressor for a reg no.
Awesome-just did that. Thank you.
@jvanzyl
As far as I am aware, the luk I have is stock.
