Whats involved in removing the door mirror?
Started by normanh, May 15, 2023, 16:47
normanh
I need to touch up the paint on one of my mirrors so how is it secured?
Remove door card, surround to lever, speaker cables I understand that.
I assume there is a simple cable socket arrangement for the mirror electrics?
How is the mount secured through the door skin to the mirror?
Have I missed anything?
Norman
It comes off as a full unit, mount and mirror, just the two fastenings through the skin.
MrChris
I've just done this, 2 nuts need removing with a 10mm socket and the unit slides up and out. Accessible after door card is removed. It is fairly clear looking at it. I seem to remember the cable just disconnects.
normanh
Thanks guys, I just like to have this sort of info available beforehand. I assume a 1/4 inch drive is adequate to remove the nuts?
Norman
@normanh
I've not had reason to remove the mirrors but my 10mm socket is typically on a 1/4 inch drive and my favoured wrench at that size is a very short SnapOn as the core diameter of something requiring a 10mm socket will not resist much else.
As always, something that has been tight for 20 years or so would likely benefit from a drop of easing juice.
andyroo104
Normally easy to remove with a smaller socket wrench and windows down for easier access.
Sent from my SM-F936B using Tapatalk
andyroo104
normanh
TheTigerUK
Make sure when you refit the mirror you route the cable correctly or else it fouls the window glass.
