Heat shield spacer, are these available to buy ?
Started by TheTigerUK, May 21, 2023, 18:51
TheTigerUK
The top engine heat shield has two of these spacers are they built into the shield or can new ones be bought ?
That material is used in the cat heat sheilds.
They are fixed in place. Integral to the shield.
Doubt available to replace.
I had to think what these are. Now I realise I can't answer the question, mine remain in place.
TCB may be a good place to ask for a new component if available, but I do doubt that they are.
I would think that trying to remove that from a used shield will result in what you have in two pieces.
I suggest that the steel mesh is to allow a small amount of give in the fixing to the manifold.
That being the case I further suggest that the solid part is something that could be turned by someone with the knowledge and wherewithal.
The mesh could be substituted for a single / double coil  or serrated washer /s as necessary.
Tightening would be a matter of judgement to not fully compress the springs/ serrations to allow some movement. Perhaps tightened when hot, when cool there would then be a relaxation of tension.
PS
Thinking again, I would not tighten when hot, I would nip up when cold, not fully compressing the washer/s and check after a run that the screw head is still in contact with the washer/s and adjust or not accordingly.
TheTigerUK
Quote from: Joesson on May 22, 2023, 22:25@TheTigerUK
Any progress?
I fitted the shield back using some washers I had in stock without problem, I might even turn a couple up in brass or aluminium the next time I visit that area, but not found the originals which I imagine are part of the heat shield.
TheTigerUK
I received a pair of these sensor plugs today, I was very careful when I had the sensors out as I dident want to drop anything into the cats so next time I have the sensors out I will plug the holes with these to eliminate the risk.
TheTigerUK
I had a little time today (love retirement :) ) and took the space apart, there are four pieces, #1 with #2 sitting on #1, #1 with #2 pushed through the heat shield, #3 placed on to #1 that is sticking out of the heat shield and #4 pressed onto #1 so it could possibly be an obscure part ?
I might make a couple of # 1s and reuse 2 & 3 and perhaps make a couple of #4s or just use a washer.
ps: See what I mean about retirement and time on our hands :)
