Weird sized and extra thick drive shafts
Started by MrT, May 23, 2023, 21:55
MrT
Hello group
I am trying to replace the CVs on my mr-s but I cannot find what parts should fit.
I've found the outer CVs come from the same era e120 Corolla with 29 teeth.
The inner UJ tripod is also a 29 tooth spline.
The mid shaft is a 20 spline fit to the transmission and the shaft is significantly thicker than mr2 options.
I cannot find how these have been made up or from which model or why they are so heavy duty. They came off my FL which I thought was stock but always suspected it was a cobbled together parts car..
Does anybody have any ideas about these please? I'm having to buy replacement shafts just to get the car running again for Hatton...
Tyler
@MrT
If I have the right member, I still have the arms and shafts I picked up from you.
Might they be of use to you?
MrT
Quote from: Ardent on May 23, 2023, 22:33@MrT
@Ardent yes sir those would be a great help thanks. Where are you located and when could I collect please?
Tyler
Tyler
MrT
I still want to know what on earth rare frankenshafts I have currently on my car. Does anybody have any information?
Tyler
Tyler
MrT
Folks here is a comparison of the original MR-S drive shafts and the frankenshafts that were on my FL. Are these Corolla T-Sport 2zz shafts or something? They are much thicker and have different CVs and UJs.
The green shafts are the frankenshafts...
Left
Right. Same carrier bearing but different tripod spline
Tyler
Tyler
There is a difference between FL and PFL
FL are stronger.
Don't know if thats the case with yours.
MrT
Thanks Scotte
But nobody lists matching CVs or UJs for my driveshafts. Even the half shift I can't find a replacement for.
I tried comparing every front/mid transverse engine Toyota I could on parts sites, even autodoc. Couldn't find a match.
Heaven knows what these are then...
Tyler
Tyler
