Functional front splitter
Started by Gaz2405, May 25, 2023, 21:26
Gaz2405
I'm struggling with space under the car in terms of making a robust enough splitter that will provide some real down force.
Using 15mm plywood that is.
I'm tempted to just got bumper mounted with a small one as I still have a full flat floor.
Anyone else got some wisdom they could throw my way?
Look up youtube.  There are vids by 'boffins' about them.
tom256
Quote from: Gaz2405 on May 25, 2023, 21:26I'm struggling with space under the car in terms of making a robust enough splitter that will provide some real down force.
TRD works but it makes noticeably  difference over  180km/h+
What is interesting after assembly full TRD aero kit, fuel consumption decreased.
Toyota MR2 Roadster 2005 TF300 Silver Streak Mica
Team Impul NS-GT2 '17
Zero header + Zero cat + TTE Exhaust
TRD Door Stabilizer
Denso TT Iridium
Mark A
The recent post by TougeTime on a fictional front splitter is worth a watch
https://youtu.be/cC8IMp1pAx8
Mark
Quote from: tom256 on July 10, 2023, 23:05What is interesting after assembly full TRD aero kit, fuel consumption decreased.
Totally logical. Not writing ´told you so´  O:-)
The OEM shape is pretty bad both as inverted airfoil and drag behind the round bum. By improving air flow under the car; i.e. less lift under the front and more out of the back it gets both ´more downforce´ (less lift) and less drag (better fuel economy).
And it does not need a full TRD kit for that  ;)  Beer money for rubber strips, a jig saw and a dremel will do  :))
Gaz2405
Got mine very similar to his.
