Oil leak
Started by M.Dub, July 26, 2023, 12:14
M.Dub
Looks like I have a bit of a weep / leak.
Big job to fix?
Noticed oil around the sump but looks like it's coming from above, replaced the O ring on the tensioner a while ago and it still looks good.
This a DIY job or not?
Was just giving the car a once over before booking a track day 🙄
Assuming the O ring is doing its job (if it's a Toyota one it might not be), then it's almost certainly the cam cover gasket.
Easy half-hour job.  Get a good quality replacement.
I'm happy to send you a better O ring courtesy of the club, just PM me your address.
M.Dub
Thank you I'll take you up on that 👍
The cam cover gasket looks dry ( see pic ).
I'll give it a quick clean and see if it's obvious where it's coming from.
Is there a gasket near where the exhaust manifold meets the block? Could it be weeping from there maybe?
Quote from: M.Dub on July 26, 2023, 14:50
Nothing else close to that area.
M.Dub
Could it be cylinder head? Really hope not 😬
Very very unlikely.  Send me your address and I'll get an O ring off to you.
