2zz 6th gear on input shaft
Started by Benlake, September 5, 2023, 08:24
Benlake
Does anyone know anybody who's done a 2zz conversion and didn't use the standard 2zz 6th gear? I chipped mine trying to remove it (trying to fix a suspected 3rd/2nd gear synchro issue) but now I also need a new 6th gear :(
Mark A
Not sure I understand the question, I thought the preferred option was to run the 1ZZ 6th gear as it is slightly longer. I run the standard 2ZZ 6th gear but I just wear headphones when on the motorway.
Have you looked Amayama looks to be about £64 per vat and P&P  33429-12010 double check this
Benlake
Its ok thanks - I ended up sending the box to Rogue after braking both 6 gears I gave up!
I've got a 6th gear set you can have. You'll need to remove it from the shaft yourself though. Just take the whole box, 3rd is toast but the rest of the gears will be fine.
