Broken volume knob
Started by Anonymous, June 7, 2005, 21:18
Has anyone else suffered from a broken volume knob where sometimes turning the knob down turns the volume up?! If so, what's the fix?
Never heard that one before... What stereo is it (the early Sony, or the post '03 Fisher Price one)?
2001, so Sony double din
Mine was the same - I think it's actually quite common with the Sony stereo.
You might be able to take it all apart and clean the optical sensor - although something odd that I noticed was that when you're setting the time with it, it worked perfectly.. it only ever played up when setting the volume. Most odd.
Personally I "fixed" it by changing the stereo  s:) :) s:)
That was my thought, but I've only had the car two weeks, so I wasn't going to get greedy!
Quote from: "aaronjb"Personally I "fixed" it by changing the stereo  s:) :) s:)
Or by buying a Fisher price replacement HU cheap from someone on here that has upgraded  s:wink: :wink: s:wink:
Or get one of the remote stalks.
Darth Paul
I had that problem on my first '2. Had it changed under warranty, and that head unit is now in my second '2. I insisted Toyota swap them out!  s:lol: :lol: s:lol:
Liz
Isn't there a reverse option on the button for the stereo, maybe someone has changed yours around, I am sure that I have seen it on the setup button when you press shift...will get dressed and go out and have a look!
I don't think that's it. The volume does go down some of the time, and always goes up when turned the other way!
SteveJ
Quote from: "Liz"Isn't there a reverse option on the button for the stereo, maybe someone has changed yours around, I am sure that I have seen it on the setup button when you press shift...will get dressed and go out and have a look!
The reverse option is for the remote stalk, and is used if you mount the unit on the right hand side of the steering column  s:) :) s:)
Liz
Had a check the reverse applies only to the Remote Module. You can change which way up and down for the volume, I unplugged it and tried it just on the volume button and it didn't make a difference...will go and sit down in the corner now like a good girl!
Liz
Quote from: "SteveJ"The reverse option is for the remote stalk, and is used if you mount the unit on the right hand side of the steering column  s:) :) s:)
Think we posted that at the same time!
QuotePosted: Tue Jun 07, 2005 8:18 pm    Post subject: Broken volume knob
Has anyone found a fix for this as mine is the same. Sometimes the volume goes down as you turn the volume up, keep turning it up and it suddenly blasts you at full volume. Most strange.    s:roll: :roll: s:roll:
cheapest fis is the remote stalk, payed a £5 for mine off ebay.
Thanks, but not knowing what to look for do I just search for stereo remote stick? Sorry if that sounds dumb  s:? :? s:?
Cheers, just found the same in the  manaul  s:oops: :oops: s:oops:   can't believe I actually read it at last  s:D :D s:D   Think I'll get one as I'm so used to having one in the Focus.
