Part nr for Bolts
Started by MRSwede, October 16, 2023, 16:17
MRSwede
Anyone got the part nr for the bolts holding the rear brake pad bracket (torque plate).
Purchased at the local Toyota dealer part nr 90105-122208 but it is to long (5mm)
Quote from: MRSwede on October 16, 2023, 16:17Anyone got the part nr for the bolts holding the rear brake pad bracket (torque plate).
If I am correcting in my understanding of the part you want those you have are likely for the front. Unfortunately no part number.
I still have the old " bolts"/machine screws/  12mm fully threaded that I removed from front and rear calipers.
The fronts are 30 mm and the rears are 25mm also have a captive flat washer.
PS This  could be the part number :
 59 (600, 44)
MRSwede
Yes The bolts i got from the dealer is probably for the front.
The rears are M12x1,25x 25, not that common in the local hardware store.
