Warning lights, SMT Warning, Battery Warning, No Gear Indicator lights and no t.
Started by Johnny_Bintang, November 21, 2023, 19:14
Johnny_Bintang
Just bought my 1999 MR S. Great car and was no problem at all coming from Devon to Cardiff.
The next day when starting the car the following warning lights came on, oil, battery and SMT. The temp gauge stopped working and the gear indicator lights and LCD stopped working.
Checked the voltage to the battery, 14.1 volts with the engine running, so alternator is ok. Gears engage properly with no lag. Oil level is fine. Car still runs fine
On restarting the car, all seemed fine but after a minute of running, the gear indicator lights stopped working and the battery light came back on. Also the temperature gauge suddenly dropped.
Anybody have any ideas?
As far as I know there are no SMT experts on here.  I hope to be proved wrong.
MR2 Spyder SMT Group on Facebook is probably your best bet.  There are knowledgeable folk in it.
A couple of smt owners on here
@Petrus for one.
May or may not be SMT related. I know the battery has had the multimeter on it, but quite often, when the dash lights like a Christmas tree, the alternator often turns  out to be the culprit.
@Johnny_Bintang any fault codes?
As engaging ok does not sound like smtbneeds resetting.
But all the other lights.
Back track search  alternator threads.
@Johnny_Bintang
Issues above aside.
Hello and welcome. Regardless of history.
Give a service. Including a maf clean.
Quote from: Johnny_Bintang on November 21, 2023, 19:14Anybody have any ideas?
not likely to be smt related.
As was mentioned first check the alternator: The conector, regulator et all.
Next battery connections and mass.
Johnny_Bintang
Thanks everyone.  OK, alternator will be checked along with associated wires. Anyone know of a good mechanic in Cardiff for MR2 roadsters?
Quote from: Johnny_Bintang on November 22, 2023, 11:17Thanks everyone.  OK, alternator will be checked along with associated wires. Anyone know of a good mechanic in Cardiff for MR2 roadsters?
The engine is common to many Toyotas, as are many other parts.  What you need is a good local family garage with a good reputation.  You don't need a specialist.
Johnny_Bintang
Thanks for all the advice.  I have just taken the car out again today.  It was working fine and all lights were out with gear indicator working too.  Then it all started again.  When I got back I tried shifting gears from neutral, first, second and reverse without the engine running and it was back to normal again.  Start the engine and .... POOF! all lights on again.
So could well be an alternator fault then?
MRSwede
You should check the (- ground) connections, could occur many strange faults, with corroded or lose ground
fawtytoo
Quote from: Johnny_Bintang on November 21, 2023, 19:14when starting the car the following warning lights came on, oil, battery and SMT.
That's the same for any car prior to actually starting it. So, as Caroline said, it's electrical. But, as an SMT owner, I can tell you it's not the SMT. If it was SMT, you would only have an SMT light on and no other fault.
To add, an SMT fault would not cause the oil light to come on, nor affect the temperature gauge.
fawtytoo
Johnny_Bintang
