O2 Sensor Sockets on eBay...
Started by so.simple, June 9, 2005, 23:28
so.simple
Carlos
Should work fine on our cars I think, admittedly that's not the greatest angle of photograph to tell from  s:) :) s:)  But looks fairly standard..
Top tip if your crows foot socket (i.e. one of those) 'opens up' when applying torque to undo a stubborn O2 sensor - put a jubilee clip around it once you've fed the O2 sensor wires into it and tighten it up..
so.simple
Thanks for the help Aaron.   s:wink: :wink: s:wink:
Carlos
Jap GT300
How would you turn that socket?  With a 1/2" breaker bar?
i'm sure i've seen them cheaper than that once you've taken the postage into account
I paid about that for a Draper "proper" one from one of the tool shops on the web.
However I am sure you might find them excl postage in local shops.
Quote from: "Jap GT300"How would you turn that socket?  With a 1/2" breaker bar?
Or a big wrench and extension.. just use it like you would any socket..
Jap GT300
It just looked wierd with the hole being offset.  I suppose it gives more leverage though
Quote from: "Jap GT300"It just looked wierd with the hole being offset.  I suppose it gives more leverage though
more like a crow's foot
They are a little odd to use, since you're not applying the torque directly.. You can get really long ones that go over the whole body and work like a normal socket, but I've only seen one - and it was worryingly cheap..
Quote from: "kanujunkie"more like a crow's foot
Which is why they're called 'crows foot sockets'  s;) ;) s;)   s:D :D s:D
