I need to clear a code
Started by Smithy, February 13, 2024, 20:31
Smithy
Good evening all. I fitted a new exhaust manifold gasket at the weekend and while I was taking it for a test drive I had an engine code appear. Looking at the engine bay I realised that I hadn't reconnected one O2 censor. What's the best way to clear it without a code reader or is that the only way?
Thanks all
03 Astral black MR2 OEM+
tomato
 Can unplug battery, leave for 15 mins or so,check battery drained by pressing horn.
Reconnect ecu will reset I believe
As said above, disconnecting the battery will do it, the car will then relearn the settings over the next few miles of driving (10-30 miles?).
Equally, if you have corrected the fault, the car should detect this as you drive and I imagine the code would disappear once the ecu detects the sensor again.
paulj
I think the Car Scanner app on android will reset ECU as part of the free of charge offering.  I know you said you haven't got a reader, but a cheapy OBD reader is less than £10 and the app is free.  I keep the reader in the glove box and my phone is with me so always ready for any pesky codes.
Today
In the late 1980's
Smithy
Battery disconnect for 30mins did the job. Thanks everyone.pailj I will definitely look into an obd scanner to work with the phone app.
Thanks again everyone
Chilli Girl
