Steering rack
Started by Newbie57, February 26, 2024, 18:38
Newbie57
My rack has dumped its fluid by the looks of it. Probably the pipes. Is there a how to on changing them out? E bay replacements look fairly cheap.
No idea if there is a how to, but I have the manual so I can retype the process for.
I have to do this myself at someone anyway.
J88TEO
Very easy process.
Just be careful not to crossthread the feeds.
Newbie57
Quote from: jvanzyl on February 27, 2024, 07:31No idea if there is a how to, but I have the manual so I can retype the process for.
Thanks that would be great
Quote from: Newbie57 on February 26, 2024, 18:38My rack has dumped its fluid by the looks of it. Probably the pipes. Is there a how to on changing them out? E bay replacements look fairly cheap.
I've had search through the How-Tos and steering pipes isn't in there, which is a surprise, as I thought it would be.
Perhaps you could write one as you do the job?  It would be greatly appreciated. :)
Newbie57
Any idea on the torque settings for the connections
I did a fluid change a while ago with ravenol. As the system will be virtually dry once the pipes are changed I'm not sure what the bleed procedure would be. Doesn't seem much pointless in flushing into a jar.
Quote from: Newbie57 on February 28, 2024, 20:52Any idea on the torque settings for the connections
just do it by feel.  Good and snug.  check for leaks if any joint drips, nip it up.
Get the front wheels off the ground. Disconnect the rubber return hose from the pump reservoir. Put the end of the hose into a plastic bottle and turn the steering wheel from full lock to full lock several times. That will get all the old fluid out of the steering rack.
Reconnect the hose and add new fluid (making sure it is a proper Electric Power Steering fluid that is compatible with the steering system. Ravenol E-PSF is good). Fill the reservoir to halfway, switch the car on and turn the steering wheel from lock to lock, keeping an eye on the fluid level. Allow the level to drop but don't let it get quite to the bottom. Top up to the lower fill line and keep turning the steering wheel.  Repeat the process until the fluid level is constant.
Hey sorry for delay..
been reading through the manual and the torque settings are VERY low. So as Carolyn says they need to be done up as you would tighten a tap to close off the water.
The o rings will need to be replaced but new power steering pipes should come with turn on.(Manual says to coat them with power steering fluid).
Going from the pump you have two lines, one is a rubber pipe the other is a metal pipe. This metal pipe is supposed to be done up at 43Nm.
On the other end (basically the two metal pipes held together by the clamp) these are to be done up at 22.5Nm.
Access might be an issue so probably practicing on another nut and bolt setup with a torque wrench and holding it at the length to which access would allow you for a spanner etc in the frunk so you can get a good feel for what it should feel like in terms of tightness might help.
From what I can tell the manual is specifically stating you should use a torque wrench with 345mm length.. probably because access is a problem.
Newbie57
Thanks for all the info.
Newbie57
Progress so far.
Took all the plastics out of the frank.
Undo bracket on the rack.
Undo right hand (looking from the front) tube connection on the rack. This was relatively easy.
Undo left hand connection. Not much space to do this. I found the nut really reluctant to come off but got there in the end.
Undo the connection at the reservoir and pull off the return tube.
Take out the tube assembly and place the new one in.
That's as far as I have got. The nuts at the steering rack end are proving very difficult  to get the threads to engage. I cut off one of the old ones just to check there was no issues with the thread that was ok so it's just fighting  with the alingment
Quote from: Newbie57 on March  6, 2024, 20:13Progress so far.
In such a case I would back off the end you have completed so that that end is just engaged and hopefully allow the troublesome end a little more wiggle room. I would not use a spanner until you have the threads well engaged at each end.
J88TEO
New pipes come with the clamp midway - loosen that clamp or take it off completely. Easy to maneuver the connecting pipe and nut so you can finger tighten it.
Newbie57
Jay
Replaced my steering rack at the weekend, thought I better upload the pics before I lose them.
Bonnet up and removed the frunk plastics and alarm siren, as you can see there's a fair bit of corrosion hiding down there:
PAS pipes are held in place with a 10mm
The joint that connects to the steering column is a bit of a faff to remove depending on the corrosion (mine had plenty). 12mm bolt at this end to remove:
Couldn't see a drain point on the old rack so just cracked the two pipe connections as they were coming off anyway:
Drained into a suitable container:
Jay
The tie rods either side needed undone, highly recommend the battery impact gun for this, made life a LOT easier:
The two main bolts that hold the rack in were next, there's a nut on the rear to hold whilst these are being loosened:
On the inside there's two 12mm bolts holding the joint to the column.  Hopefully you lot are more slender than I am as that footwell was a squeeze:
One removed old and crusty steering rack:
Jay
Took a few comparison pics of the old and new racks/joints.  I decided to import a fresh one from Japan as the condition of stuff is massively different than what I see locally.
I did have to remove and refit my steering wheel to get everything pointing straight again.  Will revisit that once I've attempted MOT and got it near an alignment ramp.
Took a bit of time and wire-brushed as much rust as I could then coated it in underbody stone-chip.  Took the bad look off it at least. Had to delete the frunk completely as the TRD brace is not friendly with it.  Alarm now moved to the exterior.
Quite a nice night so I had a few beers to celebrate
Quote from: Jay on July 25, 2024, 18:08Had to delete the frunk completely as the TRD brace is not friendly with it.  Alarm now moved to the exterior.
It definitely is compatible with some quick fettling:
Jay
Cheers Alex, what fettling is required?
Wouldn't mind retaining the storage space!
Quote from: Jay on July 25, 2024, 21:05Cheers Alex, what fettling is required?
I cut about 8cm off the back with a jigsaw (and trimmed the rubber gasket accordingly).
The back of it should then just slip under the brace, and the front clips keep it in place as normal.
