Black 04
Started by Hext007, June 3, 2024, 21:42
Hext007
I expect if you've been on Facebook you would have seen this advertised, but I will add it here just in case anyone hasn't seen it.
Finally Time to Sell The MR2, bought in January 2016, I am the second owner.
Car is on Autotrader, due to image size I could only add 4, she has been totally reliable over the time I have owned her, I have completed a few mods over the time I have owned her. TTE bodykit fitted, genuine rear spats and side skirts, replica front spats as I couldn't get any. Tein lowering springs, TTE exhaust fitted, split apart packed with high quality exhaust wadding and re welded, also installed new flexis on the genuine cat. Welding completed by a coded welder. Markii type pipe made up from stainless steel for the intake. Stereo upgraded, new door speakers, underseat sub fitted in the passenger storage bin, and a bluetooth head unit for music/ calls. I have completed all the maintenance and mods myself, this year I have replaced the battery and serviced the rear brakes, this included removal, regreasing, new springs, and the all important genuine Toyota handbrake cables, handbrake feels nice now when you pull it up. A couple of years ago I went through the entire exhaust, removed the pre-cats, replaced the manifold studs/ three amigo's, new genuine Toyota exhaust gasket etc. Unmarked Ronal alloy wheels, same sizes as face lift, little change in the offset so that they fill the arches a little bit more.
I am located in Bristol, looking for £3995, at the moment I do not want to split the hardtop.
Air con doesn't blow cold, no flashing lights etc when button pressed, compressor works, never had it regassed as wasn't bothered about it, may need gassing, or could be the cooling rad etc gone.
Hext007
Ah man- I remember meeting you at ding day. I hope all is well, and best of luck with the sale.
Hext007
Car has sold.
