Brake Ducting
Started by Benlake, July 22, 2024, 11:13
Benlake
Was wondering if any members have removed fog light and fashioned some brake ducts? I manage to over heat the brakes sometimes and get fade. I have braided hoses and carbotech pads on standard pagid discs.
I think some ducting might help. But would be interested if anyone has tried this? Maybe it could also give pads a longer life.
I was at Blyton which is known to be very hard on brakes, due to the lack of any proper straights.
MrChris
I've seen it done on others' and have been considering doing it myself. I managed to warp discs on mine. I think it should be relatively straightforward as there's a reasonable amount of space behind the bumper.
You need to relocate the washer bottle to fit ducting to the fog light holes. Never bothered as I'm lazy.
Iain
Removing the disc back plates helps
Quote from: Benlake on July 22, 2024, 11:13I manage to over heat the brakes sometimes and get fade.
Swap in the Prius 2 calipers. Apart from being shockingly lighter, they dissipate heat way better.
mr9
Quote from: Petrus on July 24, 2024, 20:38Swap in the Prius 2 calipers. Apart from being shockingly lighter, they dissipate heat way better.
For sure? Aluminium conducts heat better, but if the limit is the airflow then the conductivity of the caliper housing isn't the limit.
Also being lighter will mean you got the limit quicker.
Quote from: mr9 on August 10, 2024, 18:55For sure? Aluminium conducts heat better, but if the limit is the airflow then the conductivity of the caliper housing isn't the limit.
High thermal conductivity materials , such as copper and aluminum, are good at transferring heat. Aluminium being the less costly and lighter material is typically chosen for heatsink designs.
mr9
Quote from: Joesson on August 10, 2024, 19:54High thermal conductivity materials , such as copper and aluminum, are good at transferring heat. Aluminium being the less costly and lighter material is typically chosen for heatsink designs.
I did my university divan year project on heat sink materials, and there are diminishing returns depending on the airflow to the heatsink
My point was, is the problem of brakes overheating because of the steel calipers not conducting the heat from the inside on the pads to the outside of the caliper?
I don't know for sure which is why I asked, but I'm sceptical.
If the thermal conductivity is "good enough" then the airflow to remove the heat is the problem.
Aluminium isn't going to do anything other than lower the thermal mass if airflow is the issue.
It has been tried and tested with success.
You choose. Enjoy!
Quote from: mr9 on August 10, 2024, 23:09I did my university divan year project on heat sink materials, and there are diminishing returns depending on the airflow to the heatsink
If you accept that aluminium has a better thermal conductivity when compared with that of iron or steel, then an aluminium caliper will conduct heat better than a steel or iron caliper.
The placement of either caliper in the same airstream will mean that the aluminium caliper will conduct / transfer heat into that airflow faster than from a steel or iron caliper.
The same principal would apply with no air movement and then the coducted  heat would tend to create an airflow.
I believe that an aluminium caliper , all other conditions being equal, would result in cooler brake pads.
