Lowering springs that lowers less than 30mm?
Started by Bugster_MR2, July 24, 2024, 12:43
Bugster_MR2
Hi
It is about time to do replace a bunch of parts on my TTE Turbo. :)
I ordered KYB dampers, strut boots, top mounts, rear calipers, rear and front stabiliser links today from Rock Auto. Rock did not show any springs at all.
I am Norway-based. Looking at catalogues from the largest Norwegian suppliers, but can only find stock height springs, H&R 30mm kit and Eibach 30mm kit. As much as I love the ride quality of both H&R and Eibach products, I would ideally wish for a little less drop. I appreciate having some shock travel since our roads suck, and winters are harsh. 10-20mm drop would be enough. Otherwise I would rather go stock height.
Do you have any recommendations for springs lowering from 10 to 20mm?
Thanks in advance.
Bug
Bugster
2001 red with KW3, TRD rear brace, Zero race cat and MAF-mod.
2003 silver TTE Turbo, underbrace, sidescoops, style bar, front bumper, rear spoiler, interior garnish, exhaust
Your best bet will be stock springs, cut off part of a coil a coil with new flat ground under the cut.  I'd start with 1/3 of a coil and see how you like the result.
Bugster_MR2
Quote from: Carolyn on July 24, 2024, 13:07Your best bet will be stock springs, cut off part of a coil a coil with new flat ground under the cut.  I'd start with 1/3 of a coil and see how you like the result.
Thanks, Carolyn. But I don't like to cut coils. Reminds of what we did when we were 18 and broke.  :o  ;D
Then I'd rather run at stock height, really.
Bugster
Gibla
Fwiw I have one car running on recently fitted Kybs dampers and springs(oem height) and another one running on Kybs dampers with Eibachs (30mm lowering)
There are other differences in tyre sizes and brands used, but handling wise there is damn all of a difference, however, and this is where I agree with you @Bugster_MR2 the ride quality is definitely compromised with the lowered springs.
Maybe simply go with Kybs with oem drop?
2001 Dark Green MR-S (6R4)
You may not actually get the advertised drop. I fitted eibach 30mm drop to my erm, mx5 which is fitted with the bilstein sport dampers and only got a 20mm drop.
Could you try them and sell them on if the drop was too much? At least that way you know that they were too low for you. Better to regret what you have done rather than what you didnt do?
Jared
I was thinking the same, there is a chap on ebay who is selling a set of tein's unused for £75 but Im worried the ride will be too firm and I will rub the underside of the car on every speed bump if I lower the car 30mm.
Also getting in will be even harder......
Bugster_MR2
Quote from: Topdownman on July 24, 2024, 15:07You may not actually get the advertised drop. I fitted eibach 30mm drop to my erm, mx5 which is fitted with the bilstein sport dampers and only got a 20mm drop.
I'll take my chances. H&R 30mm now ordered. Thanks for all replies. :)
Bugster
Quote from: Bugster_MR2 on July 24, 2024, 14:05Thanks, Carolyn. But I don't like to cut coils. Reminds of what we did when we were 18 and broke.  :o  ;D
Works very good though in this case, no down side really.
Before I had the opportunity to go TRD Sportive I had no choice and was positively surprised.
Beachbum957
We are running H&R springs and have about a 25 mm drop front and rear.  We run a slightly thicker front spring insulator (Energy Suspension 16.6101) that raised the front a small amount to give a bit more travel.  We also cut the front bump stop 25 mm to just under the groove for the boot, also to get more travel.  The rear bump stop was not modified.
A problem with lowering springs is they have a stiffer spring rate than OEM and the damping rates on OEM type struts like KYB don't match well with the higher rates.  We had much better performance with Koni inserts as they have less compression damping and adjustable rebound.
Quote from: Beachbum957 on July 24, 2024, 19:58A problem with lowering springs is they have a stiffer spring rate than OEM
Exactly.
Apart from the mismatch with OEM damping rate it also increases the demands on the stiffness of the tub.
J88TEO
I have TTE springs on Koni inserts and on not so smooth roads, the ride can be rather harsh. On smooth roads, they are perfect.
Quote from: J88TEO on July 25, 2024, 09:09On smooth roads, they are perfect.
Ah, many such twisties about where you drive?  ;)  ;)
Over here the roads a generally véry well maintained but the nature of mountains means that for spirited driving over mountain twisties, ground clearance, wheel travel and good conformation are higher on the list than anti-roll and/or stiffness.
J88TEO
Quote from: Petrus on July 26, 2024, 08:40Ah, many such twisties about where you drive?  ;)  ;)
Yes, on smooth and twisties, the ride is pefect ( I have TRD ABRs ), very slight body roll.
Bugster_MR2
Quote from: Beachbum957 on July 24, 2024, 19:58We are running H&R springs and have about a 25 mm drop front and rear.  We run a slightly thicker front spring insulator (Energy Suspension 16.610) that raised the front a small amount to give a bit more travel.  We also cut the front bump stop 25 mm to just under the groove for the boot, also to get more travel.  The rear bump stop was not modified.
I got curious about the Energy Suspension products you mentioned. But can't seem to find the exact number you are referring to. Is is this vendor? Or maybe even this article nr? It is the closest I can find.
 https://teamenergysuspension.com/product/energy-suspension-16-6104g-front-spring-isolator-set/
Bugster
Beachbum957
Sorry, bad cut and paste.  The part number is energy suspension 16.6101
https://teamenergysuspension.com/?s=16.6101
What it looks like installed. It replaces the OEM insulator
Here is where the bump stop was cut.
SurreyMR2
Fitted 1 year old used H&R springs to my PFL along with new KYB shocks.
Before on OE springs Rear 63mm Front 63.3mm
After on H&R springs Rear 61mm Front 60.5mm
So drop is 20mm rear & 28mm front
Ride quality is very good & handling is much improved. Local speed bumps were not a problem.
Bugster_MR2
Bugster
