Iridium Spark Plugs
Started by Pete McCue, September 16, 2024, 11:09
Pete McCue
Wow, just wow!
I've always used iridium plugs in my cars if they are available, but I've never known such an improvement over stock NGK v-groove plugs. So smooooooth.
If there was a marked difference, word would have spread.  What's more likely is one or more of your old plugs was failing.
Pete McCue
Quote from: Gaz mr-s on September 16, 2024, 22:24If there was a marked difference, word would have spread.  What's more likely is one or more of your old plugs was failing.
Nope, don't think so. I've done about 800 miles since buying the car and thought it was running sweet as a nut, never missed a beat but the iridium plugs improved it. Actually, the Toyota service manual states that the engines should have iridium plugs fitted as standard.
Pete McCue
If you can tell the difference between a good running engine on normal plugs and iridium plugs, you'd be the first person I've literally ever heard of to be able to do that in 25 years.
The Occam's razor suggests placebo os the most likely outcome.
Most people don't want to admit it though.
Pete McCue
Quote from: Alex Knight on September 17, 2024, 06:58If you can tell the difference between a good running engine on normal plugs and iridium plugs, you'd be the first person I've literally ever heard of to be able to do that in 25 years.
Maybe so, but never had it before. 😎
Iain
They're nonsense. If you have felt a difference there was something wrong with the old ones.
Pete McCue
Quote from: Iain on September 17, 2024, 10:06They're nonsense. If you have felt a difference there was something wrong with the old ones.
OK, if it makes you happy. 😎
Think we've made the point. Let the guy be happy with his plugs :)
It's money spent, and happiness ensued. It's a win
I've removed two further replies.  It was becoming a little abrasive.  'Nuff said on the subject.
