Tensioner Rattle? (2ZZ)
Started by Alex Knight, October 12, 2024, 14:37
Hi all.
I have over a while now developed what I think is a tensioner rattle, but I can't be sure, and I would like a second opinion.
Let me know what you think:
https://youtube.com/shorts/XOnhSnM-MCM?si=F54ir1BVv_NxGqfx
https://youtube.com/shorts/bPDPC3-lvzk?si=MwW5zXNtlD25w7px
Could be.  Hey they're cheap enough that replacing it is the simplest way to find out for sure.
An easy way to find out is by pulling in valve cover and you can see down to the tensioner to see how far it's pushed out against the guide.
Update:
I've removed the tensioner, and it sounds goosed to me.
https://youtube.com/shorts/J4pOo_36XIw?si=qFvkGBk49_dWi50f
And if it is indeed goosed (Andy Ball, formerly of Bonsai tells me it is), can you replace just the pulley, or is it good practice to replace the whole assembly?
I see MWR sell the tensioner:
https://www.monkeywrenchracing.com/product/qrp-accessory-belt-tensioner-spring-damper-only-2zz-1zz-all/
And the pulley:
https://www.monkeywrenchracing.com/product/qrp-accessory-belt-tensioner-pulley-only-2zz-1zz-all/
Anything wrong with just replacing those two parts? It's a hell of a lot cheaper.
I thought you meant the chain tensioner 😅
Ah - I too, thought you meant the chain tensioner.  I'm sure you can just replace the two parts.  The rest of it can be dismantled, cleaned, greased and reassembled.
You might see what Toyota charges for the parts???  MWR ain't cheap.
@Alex Knight
I found that TCB offer Toyota parts at less cost than some others.
I'm pretty sure this item is the same as on the 1ZZ.  If so, I've got one or two in my pile of parts.
You're welcome to one for the cost of postage.
Quote from: Carolyn on October 13, 2024, 08:41I'm pretty sure this item is the same as on the 1ZZ.  If so, I've got one or two in my pile of parts.
Yes, I think it's the same as the 1ZZ also.
That's really very kind of you @Carolyn but I think I'm going to fit a brand new part. The car sees track work, which is high load, and the peace of mind a brand new part is worth it for me. Thank you anyway.
Does anyone know how to get the tensioner damper off the engine without jacking the engine up?
There's not enough room between the shock tower and the stud to slip the damper off.
You cannot wind the stud out either because it's too long and hits the shock tower on the way out.
Any ideas gratefully received.
IF it's like the 1ZZ, you don't pull the bolt all the way out, but just far enough to lift the tensioner, with the bolt, free of the block, and take it out along with the bolt.
Quote from: Carolyn on October 20, 2024, 09:03IF it's like the 1ZZ, you don't pull the bolt all the way out, but just far enough to lift the tensioner, with the bolt, free of the block, and take it out along with the bolt.
Thank you.
I need to replace the damper/spring also as it's not serviceable, so I really need to remove it.
JayPee404
Hey Alex, sorry to revive an old thread, but was wondering what this actually sounded like? Your videos are no longer available.
My auxiliary belt exploded yesterday, and today I've replaced but I am left with a sound and trying to determine whether this is a wrecked engine or just a pulley or tensioner acting up.
https://www.youtube.com/shorts/A6E6ZwE_zvk
Thanks!
JP
Quote from: JayPee404 on February  7, 2025, 17:28Hey Alex, sorry to revive an old thread, but was wondering what this actually sounded like? Your videos are no longer available.
Thanks!
JP
The video quality makes it hard to be sure, but it definitely sounds similar.
Pete McCue
This is what mine, (1zz), sounded like and it definitely was the belt tensioner.
https://youtu.be/A1voAGuJ55E
Thanks!
JP
On listening again, it sounds like something is rattling, but I don't think it's your tensioner.
JayPee404
Quote from: Alex Knight on February 14, 2025, 16:12On listening again, it sounds like something is rattling, but I don't think it's your tensioner.
Honestly from another post somebody kindly pointed out a disconnected hose and since i plugged that back in it seems to be gone entirely! Car is currently sat at an airport carpark so hopefully no surprises when I'm back...
