2003 Black Toyota MR2 Mk3 2ZZ
Started by Dave Angel, November 6, 2024, 20:01
Dave Angel
G'day all,
My intention was to keep this as a track/summer fun car for some time but the opportunity to buy a dream car has come up unexpectedly and so I am considering selling up! I have only used it for a couple of track days where it performed faultlessly and some occasional summer drives. It has the usual chips on the front and some dents and scratches although it does clean up quite well considering its age. The subframes are in good condition but I have a ramp available so any inspection is welcome and encouraged!
I also have a 2021 Phoenix Trailers Twin Axle Twin Braked trailer which I can include in the sale which the car fits on perfectly and tows brilliantly:
Spec as follows:
2003 Toyota MR2 Mk3 2ZZ
92k
6 Speed with LSD
Air-Con Model (though needs regas)
Formula Dynamics Alloy Wheels – staggered setup 16"/15" with Toyo TR1 Tyres
MOT till Feb 2025
Bought 02/2024 – Engine was swapped circa 2022
Previous Owner Fitted – 2023/24:
Lightened flywheel and clutch
New Shocks with lowering springs
New Top mounts
Camber bolts
Front Dop Links
Whiteline Front ARB
Front control Arms
Superpro Polybushes -  Front and rear suspension
Rear Calipers
Brake discs – Front and Rear
New Coil Packs and NGK plugs
Samco Hoses and induction kit – sounds great!
4 Branch manifold – EBX copy
Longlife Back box
200Cel High Flow Cat
In my ownership I have fitted/replaced:
JP Cages Half Cage
EP Tuning Baffled Sump
New Front Calipers
Goodridge Braided Brake Lines
New Front Hard Brake Lines – Ends on original stripped!
Front Wheel Bearings
PBS Prorace Front and Rear brake pads
Barbarian Front and Rear Strut Bars and Centre Chassis Brace Bar
Coolant tank and cap
Oil Pressure, Oil temperature and Voltage Gauges
Lift Solenoid and bolts
I have also:
Carried out a complete wheel alignment and completed oil, power steering and brake fluid change - Milers CFS Nanodrive Synthetic 10w50, Ravenol E-PSF and Motul RBF600 in Spring 2024 at about 90k miles.
Replaced rear driver's side panel with good quality second hand and removed aerial
Removed cam cover and repainted to match and generally tied the car up!
Looking for £6500 for the car alone or £8500 with the trailer.
I'm located in Herefordshire close to the Welsh border.
I have loads of photos and a couple of vids if required.
IloveCurbs
What a cool car, with all needed mods to it. Unfortunatly i live in germany. It seems cheap for me, good luck. Do you want to tell what Dreamcar you are talking about?
Dave Angel
Thanks for the positive comments! I hope I have priced it fairly given the time and extras I have added to it since I bought it in Feb. If the other 'dream' car sells before I have a chance to make an offer I'll quite happily keep it! That car will probably be Lots Of Trouble (Usually Serious) anyway!!!
Dave Angel
Just an update for anyone looking:
Have just put a new MOT on the car till Dec 25
Dropped the price to £6000
Forgot to mention comes with some spares including a spare set of alloys (though they could do with a refurb).
Dave Angel
Car now sold!
