HELP! Please before I punch out my computer!
Started by Pete McCue, November 9, 2024, 12:29
Pete McCue
I'm trying to find replacement exhaust ring seals for a TTE exhaust, does anyone tell me where I can get a pair please??
Pete McCue
Thanks, but it's the metal ring seals that fit between the silencer and tail pipes I need.
These:
https://i.postimg.cc/hPyL6yvb/20241109-135442.jpg
TCB Performance Parts.
Look them up and call them on phone.  Emails can take a while...
Aren't these the ones that could be replaced with Volvo or Ford rings?
I got a couple when I took mine off I believe. Could be wrong.
Pete McCue
Quote from: shnazzle on November  9, 2024, 15:42https://www.mr2roc.org/index.php?msg=830478
A reference of a reference to a post
Thanks Shnazzle, the inner diameter is about 4mm under size but I guess they'll do if I can't find an alternative.
Pete McCue
OK, thanks for all the replies. I have ordered two lots of seals, a pair of Klarius FDG3 which say they are 54mm, (but rather un-helpfully not whether that's internal or external), and a pair of the Volvo 240 type. I'll use whichever are the best fit. I would never have guessed that a couple of exhaust seals could be so bloody problematic!! The Toyota dealer was useless, they'd never even heard of a TTE, or optional sports exhaust!
pauls0212
red 2003 standard so far
Pete McCue
Quote from: Pete McCue on November 10, 2024, 08:55OK, thanks for all the replies. I have ordered two lots of seals, a pair of Klarius FDG3 which say they are 54mm, (but rather un-helpfully not whether that's internal or external), and a pair of the Volvo 240 type. I'll use whichever are the best fit. I would never have guessed that a couple of exhaust seals could be so bloody problematic!! The Toyota dealer was useless, they'd never even heard of a TTE, or optional sports exhaust!
Bit of an update, the Klarius FDG3 seals are 54mm outer diameter so no good.
Bossworld
ECP clamps are OK but Volvo gasket is too big - my own experience back here - https://www.mr2roc.org/index.php?topic=60924.msg724679#msg724679
Not all Audi/Volvo gaskets are cross compatible. Sorry to send you on another thread, I can't find a post of my own about it, but this has more detail https://www.mr2roc.org/index.php?topic=29619.msg452193#msg452193
From old emails it looks like CEG112 is what I used as was purchased online. Whereas I remember buying some from ECP that didn't fit
https://www.ebay.co.uk/itm/230683030206?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=8d8kaVw2Say&sssrc=4429486&ssuid=7RB7W-mzTAm&var=&widget_ver=artemis&media=COPY
Pete McCue
Quote from: Bossworld on November 13, 2024, 09:41ECP clamps are OK but Volvo gasket is too big - my own experience back here - https://www.mr2roc.org/index.php?topic=60924.msg724679#msg724679
Thanks for that mate, much appreciated. I have now ordered 3 different types to compare and will report back later.
The Other Stu
Gah. And I was just talking about this last week.
I've just fitted some too in the last few days.
Gasket
https://www.eurocarparts.com/search/700660050
Clamp
https://www.eurocarparts.com/search/712745101
These are definitely the ones!
Pete McCue
Quote from: The Other Stu on November 13, 2024, 21:30Gah. And I was just talking about this last week.
Gasket
Clamp
Thanks. They are among the ones I've ordered so it' reassuring that at least those will work.
Pete McCue
Ok, so, all back together looking and sounding great!
These are the two types of seal that work perfectly. The RD1266118A was supplied in place of 700660050, and the CEG112 seems to be identical to it. I actually used the CEG112 and it fits perfectly. Job done at last!
Pete McCue
Now the bloody cat heat shield is buzzing!! Grrrrrr
The Other Stu
Quote from: Pete McCue on November 16, 2024, 11:52Now the bloody cat heat shield is buzzing!! Grrrrrr
Metal cable ties are your friend.
