New Battery
Started by Zxrob, November 15, 2024, 21:18
Zxrob
Hi All
I think its new battery time, thinking of lithium, have run them on my bikes for ages with no issues, never had one on a car, any recommendations, advice.
Cheers Rob
Adventure before dementia 😁
I know lots of people have lithium batteries.
What put me off getting one, is a story from a track Marshall at Blyton Park. He told me he watched two cars burn down to the ground (one was a 991 GT3) due to lithium batteries catching fire. An entire fire engine tank couldn't put the Porsche out. They had to stand there and watch it burn to the ground.
My 2p.
Gibla
Have used Exide ELTX20H for 2-3 years in a couple of my cars, they weigh about 1kg
One started to lose it ability to hold charge after about 12 months but was replaced foc by Tayna
Originally about £120, now nearer to £170-180
2001 Dark Green MR-S (6R4)
Gibla
Quote from: Joesson on November 16, 2024, 13:26@Zxrob
This recent Lotus EVORA thread maybe of interest:
https://www.emiraforum.com/threads/anyone-with-experience-of-lightweight-lithium-12v-starter-batteries-in-ice-cars.1811/
Good call @Joesson some mention the Antigravity battery that I just happen to have fitted to an MX-5 that I also own, whether by coincidence there is a mention of battery management issues (something somewhere in the circuitry not directly associated with the battery itself)that I have also periodically experienced. When the charging circuit is working as it should the Antigravity battery is great- albeit hugely expensive and way larger than the Exide I mentioned in my earlier post.
Gibla
My Antigravity battery on the MX-5 is WAY larger than this one on their website, but looks a good alternative to the Exide that I am using with success
https://antigravitybatteries.com/products/starter-batteries/restart-oem/atx20-rs/
Jared
I've been looking into this and not sure the lithium is worth the money. I like the idea of agm but not sure if I'm gonna be able to lose much weight over a normal battery.
Mine us a daily driver so don't want to have any starting issues but I have found a normal battery 40ah and 330ca that is 2kg less than the 45ah that I have now so for £40 it's not a bad loss.
Mine is starting to feel a tad sluggish on a cold morning....
boor
For a daily driver would recommend the oem. Better brands cames with 5y replacement guarantee - which I used twice already, as mine is a weekend car. Have some audio and additional gauges, also 2zz and supercharged, so my case is a bit different.
Friends used light weight ones and experienced some issues on daily cars - long story short, they moved back to the normal size. Great for the track, for sure.
There's always an alternative to move battery to the front on on top of the rear subframe, to get better weight distribution.
Daily: Fiat Tipo SW
Project: 03 Facelift Mr2 Roadster 2zz (Greddy Supercharger, meth injection, Apexi PFC, MWR pulleys, EBC brakes+braided lines, K&N+feed, custom mani+decat+dual TTE, full TTE bodykit+ARBs+interior, Enkei's and lots more...
Jared
Bit of investigation...
We use a 45ah battery which can use 50% of its charge so that's 22.5ah capacity.
AGM can use 80% so if you go for a 26ah (pretty common) AGM battery that "should" fit the bill and weight is around 6.5kg plus the xr-600 is about £60 so not too expensive.
