Alloys
Started by 2 of the left, November 25, 2024, 13:23
2 of the left
I have a slow leak on one of my tyres The tyre is sound but the alloy is suspect- where ca I purchase a new standard alloy?
SI VIS PACEM PARA BELLUM!!
SV-3
Quote from: 2 of the left on November 25, 2024, 13:23I have a slow leak on one of my tyres The tyre is sound but the alloy is suspect- where ca I purchase a new standard alloy?
Had the same problem with one of mine.
Turned out to be corrosion on the inside of the alloy.
Tyre place wire brushed the wheel and applied liquid rubber - problem solved.
Might save you the cost of an alloy?
Regards
Eclectic - not electric
Sony WX-920BT
"Hardtop Cognoscenti"
"Stock Cubed"
"AirCon Aficionado"
"Keeper of the Beeper"
2 of the left
Quote from: SV-3 on November 25, 2024, 13:38Had the same problem with one of mine.
Regards
same here with two of the wheels on our MG TF, they used a wire brush to remove the rust from the rims, been OK ever since
