Plasticky sounding rattle / ticking from engine
Started by Pete McCue, December 23, 2024, 12:46
Pete McCue
Good afternoon all, my car has always, (in my ownership), had this strange plasticky sounding rattle or tapping/ticking noise from the driver's side of the engine bay. It's not constant and only noticeable at idle. It's definitely not valve clearances as I've had a good listen to those and they all sound sweet as a nut. I wondered if it might be the alternator? Should have run the engine for a bit when I had the aux drive belt off. Any ideas? Cheers.
I did make a short video but don't know how to put it up.
It could be a tired chain tensioner.  They are tensioned by oil pressure and, if they are a bit worn, they can fail to tension properly at idle.
If it is the tensioner, it might only happen once the oil is warm and idle oil pressure drops.
Otherwise, as you say, pop the belt off and give it a listen. ;D
Pete McCue
Quote from: Carolyn on December 23, 2024, 13:36It could be a tired chain tensioner.  They are tensioned by oil pressure and, if they are a bit worn, they can fail to tension properly at idle.
Thanks for that. I did wonder about that but it's such a plasticy sort of sound I wasn't sure. The car's only done 43k but I suppose for £40 I could do it anyway couldn't I.
Pete McCue
Ok, so fitted a new timing chain tensioner, nice 10 minute job but made no difference. Will hopefully post a video here to see if anyone recognises the noise. I'm not concerned by it, it's just annoying. Not sure why the engine sounds like a tractor!  :))
Have you checked your flexis for holes? Sometimes the gas escaping from the weave can make a strange noise like that.
Obviously this is assuming the tensioner sprang out of the clip properly before starting up.
Pete McCue
Quote from: Call the midlife! on December 30, 2024, 19:13Have you checked your flexis for holes? Sometimes the gas escaping from the weave can make a strange noise like that.
Cheers.
You mean make the engine sound like a tractor or the clicky/tappy noise? The engine sounds fine "in real life".
The tensioner definitely clicked into place.
Either/or/both... it kind of flaps as the exhaust blows through it.
Pete McCue
Had another look at this today as it's a lovely day out there. Exhaust flexys are fine. I'm pretty sure it's coming from the aux belt tensioner assembly so I've ordered a new one to see.
Pete McCue
No more clickety-clack! Happy days.
It also means I've got a perfectly good timing chain tensioner if anyone needs one for just the postage?
Quote from: Pete McCue on January 20, 2025, 16:50No more clickety-clack! Happy days.
Hold on to it.  They don't last forever.
