Main Menu
TTE exhaust.
Started by TheTigerUK, December 28, 2024, 19:28
TheTigerUK
I have no problem with my standard exhaust but I fancy a twin exit look so I have picked up a TTE but before fitting I want to source all new gaskets and clamps, if a jobs worth doing its worth doing well :)
Which if any of these two gaskets are correct for cat to back box ? (TIA).
The one on the left from ebay and the one on the right MR2-Ben, profile and size differ a great deal.
https://www.ebay.co.uk/itm/205127611332
https://mr2-ben.co.uk/products/941
A side from gaskets. Did it come complete with the extra support bracket for the right hand side pipe?
If you want my advice, only use the genuine OEM gasket.
TheTigerUK
Quote from: Ardent on December 28, 2024, 20:34A side from gaskets. Did it come complete with the extra support bracket for the right hand side pipe?
Yes it did.
TheTigerUK
Quote from: Alex Knight on December 28, 2024, 22:21If you want my advice, only use the genuine OEM gasket.
Thank you.
The two metal O ring gaskets that sit between the box and the pipes has recently  been discussed here along with the V band clamps.
Pete McCue
Both of these are perfect for the job.
TheTigerUK
Quote from: Ardent on December 29, 2024, 08:27The two metal O ring gaskets that sit between the box and the pipes has recently  been discussed here along with the V band clamps.
Have you a link ? I was thinking of making two but easier to buy :)
Pete McCue
Quote from: TheTigerUK on December 29, 2024, 12:06Have you a link ? I was thinking of making two but easier to buy :)
The parts I posted above are to replace those. Either part is fine as they are pretty much identical.
Your original ones look like they'll clean up fine though, unless they are eaten away?
TheTigerUK
Quote from: Pete McCue on December 29, 2024, 13:25The parts I posted above are to replace those. Either part is fine as they are pretty much identical.
Thanks, I only have the one and I would like two new ones.
TheTigerUK
Clamps came today, great service.
Would it help preserve the clamps if given a coat of Bilt Hamber before fitting ?
Look like they would stand up well, but a bit if Bilt wouldn't hurt.
In my experience any supplementary finish applied to a plated ( in this case zinc) surface will deteriorate and flake off.
I knew not why but with the aid of the www I found this:
When you apply an alkyd oil-based paint over zinc plated or galvanized surfaces, a chemical reaction occurs between the two materials. This process, known as saponification, causes a build-up between the zinc surface and the coating. Over time, this can cause the coating to release from the surface. It is possible to paint galvanized surfaces with an oil-based system, however a water-based system will need to be applied as an intermediary coat.
Rustoleum
Not forgetting that the exhaust system and fittings get hot!
TheTigerUK
Quote from: Joesson on December 30, 2024, 16:49In my experience any supplementary finish applied to a plated ( in this case zinc) surface will deteriorate and flake off.
Interesting, thanks.
I suppose its a bit of shiny that won't be seen  :D  a dab of copper slip on the threads will have to suffice.
TheTigerUK
Autogem gaskets arrived today, offered them up and they look as thought they will do the job fine.
Sizes and shape differ a little from the original but everyone seems to think these are fine so all good :)
OEM: 65.50mm OD X 53.00mm ID X 13.40mm thick (angled sides)
AUT: 66.25mm OD X 50.50mm ID X 10.00mm thick (radius sides)
I'm lost now with this thread, I thought you were wanting the cat to silencer gasket, of which there's only one required?
TheTigerUK
Quote from: Call the midlife! on January  2, 2025, 20:00I'm lost now with this thread, I thought you were wanting the cat to silencer gasket, of which there's only one required?
I did but i'm replacing all the gaskets so thought it may be of use to others ? really sorry for the confusion :(
Nothing to apologise for, although I'm still curious why you've got 2 cat to silencer gaskets 😂
Boy scout, be prepared.
TheTigerUK
Quote from: Call the midlife! on January  2, 2025, 21:04Nothing to apologise for, although I'm still curious why you've got 2 cat to silencer gaskets 😂
Trying to find the best one :)
Pete McCue
Re the cat to silencer gasket I would think the more tapered one would fit best. The one I got was more like the fatter one and, although it seals ok, it doesn't seem to crush enough and I would rather the two flanges sat a bit closer together.
