2004 Mr2 Roadster Knocking /Ticking noise ?
Started by DMC75, January 16, 2025, 17:24
DMC75
Hi :-\
This is my 1st post: can anyone help me with this noise ?
TIA
Pete McCue
Hi mate, I'm afraid that's not a "tick", that's a knock. Not sure if it's possible to dislodge a shim on these engines, if not may be little end gone. Either way, not good but others here are way more knowledgeable than I.
Hello and welcome,
It could also be an exhaust leak, they can sound very similar.  Such a sharp sound is often caused by a leak at the join between exhaust manifold and the cat, or a small hole in a flexi.
There are no shims to dislodge, if it is  engine knock, it will be a spun rod bearing.
DMC75
I may get the dremel out and inspect further.
Quote from: DMC75 on January 21, 2025, 01:07I may get the dremel out and inspect further.
Is this some figure of speech that I am not aware of?
The Dremel I understood to be a compact high speed rotating tool holder that can be fitted with various drills and grinding stones for the removal of unwanted material!
