[SOLD] 2005 Sable Grey MR2 For Sale
Started by MrChris, March 1, 2025, 19:36
MrChris
My sable grey MR2 is for sale again. I took it off sale last time as a family member needed a car for commuting for a bit and now I have it back. Sod's law dictated that I had loads of interest after I removed it for sale and they all went and bought MR2s... never mind.
I am looking for £2,200 for it.
I am located in Aldridge, West Midlands.
Mechanically it is sorted. Cosmetically, it has seen better days but more details below.
The reg is RA05 WPE.
Some facts about it:
Just under 112k miles on the clock.
It has a valid MOT with no advisories until September 2025.
BC racing coilovers - 4 springs replaced within the last 2 years as well as front pillow ball mounts.
Subframe is good.
The pre-cats have been done (gutted) some years ago, so no worries there.
Engine running very well and serviced around 2k miles ago and regularly before this.
Valve cover gasket replaced last year.
Starter motor replaced last year.
Gearbox is good, was also serviced around 2k miles ago.
The handbrake works.
All four brakes have been refurbished: new calipers from J-SPEC, new discs and pads. Braided brake lines. The brakes are VERY good, stopping the car "on a dime" so to speak.
Clutch was done 6-8k miles ago by previous owner (shnazzle on this forum).
Rear suspension arms replaced 2 years ago.
Front suspension arms replaced last year.
4 new Toyo TR1 tyres less than 2k miles on them with four wheel alignment last year.
Plastics are not fitted currently but will be supplied (e.g. "nappy", frunk plastics etc.).
Red leather heated seats.
Air-con (but needs a re-gas as is not blowing particularly cold).
Serviced regularly.
Some things you should be aware of:
I swiped the side of the car on a tyre wall at a track day so it has had a new front panel, door and light (as well as new front arms and full wheel alignment mentioned above).
The rear drivers side panel was not replaced, it has some marks/dents on it. Doesn't look terrible, doesn't look great either. I have replacement panel that can go with the car (or I can fit it for you) for free. It is silver however. I was going to get it sprayed but have not had the time.
The soft top glass got broken and new glass was put in, but it looks messy... really messy. It is watertight.
There is a tear in one part of the roof, again, it is watertight.
Again I'll try and get some pics up of the panel and roof.
MrChris
Pictures added. Looking for sale by end of March if possible, and then potentially looking to part out but keep wheels and engine.
MrChris
£2200
MrChris
