Flywheel cover?
Started by ruud2boy, March 26, 2025, 13:16
ruud2boy
After venturing underneath my 2, I was surprised to see that the flywheel appeared to be open to the elements. This should have a casing / cover I would have thought?
They leave the factory with a clip in, plastic cover but it's easily lost, displaced and depending on if you have undertrays fitted not a massive issue either way.
You can probably get one from J Spec or any of the other breakers if you want one.
