Failed emissions
Started by kx3210, April 12, 2025, 21:55
kx3210
I found this hose disconnected.  What does it do and what is it connected to. Any idea if this would cause the car to fail emissions ?
Emissions, wouldn't think so.  It is for fuel vapour....container on right side is a charcoal canister.
What did the MOT tester tell you?  If you don't know posting a pic of the figures might help.
@kx3210
Hello and welcome BTW.
maybe say hello in the newbie section.
Do you normally run it without the rocker cover, cover?
Is it new to you?
Has it passed before?
Any changes to zorst system?
Vac leak?
Cat up to temp prior to test?
fawtytoo
O2 sensors would affect emissions.
I take it there's no engine warning light?  I suppose not, as that would be a fail. A bad O2 sensor will trigger a warning light, so it's almost certainly not a sensor.
That leaves the Mass Air Flow meter (which won't trigger an engine light) an air leak in the exhaust, or a catalytic convertor that has reached its sell-by date.
If you still have the cat it left the fsctory with, then a duff cat is highly likely.
Please post a pic of the emmissions read out that the tester gave you as that will enable us to give better advice.
Also if you get and OBD dongle and a phone app like Torque Pro, you can post any errors it comes up with.
Quote from: Carolyn on April 13, 2025, 10:50I take it there's no engine warning light?  I suppose not, as that would be a fail.
Not neccessarily, prior to a registration 1st July 2003, it's not a failure.
tets
Just to add, was at operating temperature when they tested it? It does help if it's had an Italian tune up just before the test!
kx3210
Hi - Tried again and it is still no passing emissions. CO is 2.050, HC 373 and lamba .979  The mechanic says is running far to rich and suggested the cold idle sensor? may be causing the problem. He said it wasn't likely to be the injectors. It runs well and you can hear the revs drop once it is heated up.  It has a new lamba sensor after the cat and a new cat.  New plugs, air filter.
Quote from: kx3210 on April 29, 2025, 12:55Hi - Tried again and it is still no passing emissions. CO is 2.050, HC 373 and lamba .979  The mechanic says is running far to rich and suggested the cold idle sensor? may be causing the problem. He said it wasn't likely to be the injectors. It runs well and you can hear the revs drop once it is heated up.  It has a new lamba sensor after the cat and a new cat.  New plugs, air filter.
Have you pulled the plugs and seen if it's one cylinder or all four?
kx3210
Hi - Took the plugs out and they all have soot round the body of all the plugs, they are all new.
Got hold of a Launch scanner and got this list of reading.  Anyone know if these are normal ?
IGN Advance                   15deg
IGNITION                   385
Injector                   2.816ms
Intake Air                   25degree C
Long FT #1                   8.559%
Long FT #2                   -3.156%
MAF                      3.460gm/s
MIL Status                   OFF
MISFIRE LOAD                0g/rev
Misfire Monitor                Avail
MISFIRE RPM 0rpmO2 LR B1 S1          65.500ms
O2 RL B1 S1                   65.500ms
O2 RL B2 S1                   65.500ms
O2FT B1 S1                   6.216%
O2FT B1 S2                   99.155%
O2FT B2 S1                   -1.594%
O2S B1 S1                   0.670V
O2S B1 S2                   0.920V
O2S B2 S1                   0.080V
O2S(A/FS) Heater Monitor             Avail
O2S(A/FS) Heater Monitor             Compl
O2S(A/FS) Monitor AvailO2S(A/FS) Monitor    Compl
2nd Air Monitor                Not Avl
2nd Air Monitor                Compl
A/C MAG Clutch                OFF
A/C Monitor                   Not Avl
A/C Monitor                   Compl
A/C SIG                   OFF
AS Test                   Compl
CALC Load                   14.118%
Catalyst Monitor                Avail
Catalyst Monitor ComplCheck Mode       OFF
O2FT B1 S2  99.155%
No expert. But the above looks the stand out to me.
Was going to suggest anyone local you could try swapping a maf with. Looking at your profile. Perhaps not.
No expert either, but if all 4 are black maybe that Post cat sensor reading may refer to the rich exhaust.   Maf is first thing as previously suggest by self & Ardent.  I posted a cheap one link above.
kx3210
Hi - have ordered a new MAF.  Was wondering what the reading was O2FT B1 S2 99.155%  manual says it should be 0 +- 20%
Quote from: kx3210 on April 30, 2025, 22:02Hi - have ordered a new MAF.  Was wondering what the reading was O2FT B1 S2 99.155%  manual says it should be 0 +- 20%
Link I gave you?
kx3210
Last time I buy from a link on here.  Ordered a MAF from the above link last week and it was supposed to be here by now but hasn't
even been shipped yet.  Haven't even had a response from my 2 messages asking where it is.
Quote from: kx3210 on May  7, 2025, 10:15Last time I buy from a link on here.  Ordered a MAF from the above link last week and it was supposed to be here by now but hasn't
Hey - stuff happens.  Please don't blame the club for a supplier letting you down.  99% of the stuff on here is accurate, relaible and helpful.
Don't take the hump at me.  As Carolyn states above, I was just the messenger (who put in the effort).
Have you reported it to ebay?
@kx3210
From the link, kindly provided by Gaz mr-s please refer to the following:
Located in: Dublin, Ireland
Delivery:
Estimated between Mon, 12 May and Fri, 16 May to GL11AD
That is from today, that means 5 - 9 days delivery time and that is from Dublin, S Ireland / overseas!
I have mentioned previously that persistence is one of the best tools in the tool box. As can be patience.
PS: Not to mention a weekend and a Bank holiday since you ordered on April 30, per your post at 22.00 hrs.
