Manifold
Started by Newbie57, May 4, 2025, 11:05
Newbie57
I need to replace the main cat,p420 code. I picked up a toyo sport manifold. Does this need to wrapped to compensate for the lack of heat shields?
Quote from: Newbie57 on May  4, 2025, 11:05I need to replace the main cat,p420 code. I picked up a toyo sport manifold. Does this need to wrapped to compensate for the lack of heat shields?
I am a big fan of wrapping manifolds.  It keeps the heat soak down in the engine compartment and speeds up gas flow.
Best done on the bench prior to installation.  Forgive me if you've done it before and I'm teaching my grandmother how to suck eggs, but wear long sleeves and gloves.
Soak the wrapping on water as it makes it easier to conform to the shape of the manifold, and buy good quality tape.
This will be fine:
https://www.ebay.co.uk/itm/235084083107?_skw=exhaust+wrap&itmmeta=01JTDDT9738SN9YJYT6VQZC146&hash=item36bc1a6fa3:g:FksAAOSwM9lg1GFF&itmprp=enc%3AAQAKAAAA0FkggFvd1GGDu0w3yXCmi1fCGWetUpxJoTlmyQSZijdVY8eFWt9WxdQmQPGoYgKYoZRPUklEiSOlWF8HAKUAVDTW7FCJs8MjG5NIggkMN6YA2WuUdVL3QPP373KQUPL3H7gG7IpHrPq5UAwSmkHKhQ%2By%2BXWUWTrER2%2F1Gd7Bo4STqrvqvYjdzWoo%2FK079IClzrlqJgYikpU547s5i3wmy1HAUfS5WqqHffbAcMCIQx%2Bjr2K%2B585vqPBSWBSW4Yqv0fFWVpDzO6izJtCOyBU7WYw%3D%7Ctkp%3ABlBMUOCT6a3TZQ
I'm running a type cerified cat from Cats2U. It's been on for quite a few years and it's doing the job. The car aces emissions test.  I have it wrapped from the flexis to just past the cat itself.  A hot cat is a happy cat.  That's another ten metres of wrap and a tricky wrapping job, again best done on the bench.
Newbie57
Thanks for the info
fawtytoo
Quote from: Carolyn on May  4, 2025, 11:37I am a big fan of wrapping manifolds.  It keeps the heat soak down in the engine compartment and speeds up gas flow.
Does wrapping also prevent the damage to the paint on the bumper? Just something I remember reading.
NB Does anybody actually read signatures?
Quote from: fawtytoo on May  4, 2025, 18:32Does wrapping also prevent the damage to the paint on the bumper? Just something I remember reading.
I don't know - I've never seen damge like that, but others might have?
Newbie57
Well, the EML light has now switched itself off so I'm assuming the P420 code has cleared itself. Two things were done prior to the light coming on. The subframe was replaced & I did an oil change. The exhaust was smoke checked for leaks and the O2 sensor replaced. I also changed the airfiltefand cleaned the MAF. Still got the P420 code.
I'm wondering if I overfilled the oil and that has disputed now.
Newbie57
Finally got the cat and manifold fitted. Interestingly the main cat had no honeycomb in it. Might explain the p420 code :).
I'm guessing it must have broken down and blown out of the exhaust. It's been passing the MOT for the last 10 years so either it was in there at so.e point or the pre cats were doing the job.
