FC Hako lead needed for a couple of hours
Started by tets, September 1, 2025, 10:28
tets
Would anybody have an FC Hako lead for the Apexi PFC I could borrow for a couple of hours?
I bent the USB end of mine accidentally and although I've straightened the pins and poked them back into the holes I can't get it to connect!
I've opened up the exhaust slightly and want to check everything is still on point before the next event!
I'm around Manchester
cheers
Steve
simonrobinson
I have a FC-Datalogit, not a Hako. You can use it for a couple of hours datalogging if you still need it. Near J17 off the M6. Apexi PFC uses "6 Pin Mini Din" connector same as a PS2 port although you have to snap one pin off as its a 5 pin female on the ECU. This would be very easy to fix if you turned up here with a new connector, for example these on Amazon:-
https://www.amazon.co.uk/dp/B0DNQ1DVRY/
tets
Quote from: simonrobinson on September  6, 2025, 09:34I have a FC-Datalogit, not a Hako. You can use it for a couple of hours datalogging if you still need it. Near J17 off the M6. Apexi PFC uses "6 Pin Mini Din" connector same as a PS2 port although you have to snap one pin off as its a 5 pin female on the ECU. This would be very easy to fix if you turned up here with a new connector, for example these on Amazon:-
Hi Simon
It's the usb end that plugs into the laptop that I think is knackered. The guy from FC Hako has directed me to a replacement which arrives tomorrow!
I will give you a shout if it doesn't work and really appreciate the offer!
cheers
Steve
