Handbrake MOT failure
Started by ucb, September 5, 2025, 11:16
ucb
Unsurprisingly the 2 failed its MOT yesterday on the handbrake being below efficiency. I adjust the mechanism but it just wont hold the car.
When I was adjusting it I noted the NS cable didn't move anywhere near as much as the OS, but I suppose I'm down to caliper rebuilds and new cables.
Any suggestions for trustworthy garages in the North east/Yorks for this type of work?
Chilli Girl
How annoying but sadly a Roadster's common fault, sorry can't help on garages up there.  All the best for the next MOT though. :)
ucb
Quote from: Carolyn on September  5, 2025, 13:31@ucb :
https://www.mr2roc.org/index.php?topic=68798.0
yep, thanks Carolyn.
i read your post multiple times and concluded I would need a caliper or cables or both before adjusting in cockpit.
If you're hands-on remove centre console, reduce tension right-off, disconnect at calipers & see how the cables move.
Are the rubber bellows at the caliper end intact?  If not, that's the likely cause of the problem.  By dropping rear end down & using very thin oil from inside the car, they can be 'recovered'.  And the rubber replaced.
If you need a garage to replace a cable make sure they don't chop the existing & use it to haul the new one in...it needs to be fixed around the chassis.
ucb
I'll give it a try
Sure the bellows were intact when i last checked
