Weird Intermittent Rattle at idle (2ZZ)
Started by Alex Knight, September 11, 2025, 12:03
Hi all,
My 2ZZ has developed a strange intermittent rattle at idle.
I've replaced the aux belt tensioner with a new OEM unit.
I'm thinking that it might be alternator pulley bearing.
I'm 99.9% it's not engine internals related due to its intermittent nature.
Any ideas what it might be?
Get a stethoscope and hunt around.  Take the cannister out while you do it.
@Carolyn
Possibly timing chain tensioner?
Or timing chain itself?
Either way, booked in a week on Friday as I don't have the time at the moment.
Quote from: Alex Knight on September 16, 2025, 20:50@Carolyn
Tensioners do wear out and start to leak oil past the little piston.  More likely the tensioner than the chain. The intermittent nature of it suggests the tensioner more than the chain.
Well, it seems that the issue is the  cam cover plastic which is coming into contact with the actual cam cover and resonating. Nothing more sinister than that. I just need to space it away a few mm!
