Speakers
Started by Zxrob, September 14, 2025, 14:00
Zxrob
Hi All.
Is there a direct replacement for the door speakers, I have the OE ones in at the moment but one has gone again, changed it before, not looking for anything expensive or special as I very rarely have the radio on.
Cheers Rob
Adventure before dementia 😁
I have Sony ones which are a direct replacement.  I'm happy with them - but then my hearing ain't the best! ;D
Zxrob
Carolyn.
Have you got a link or part no ref for them.
Cheers Rob
Quote from: Zxrob on September 14, 2025, 15:39Carolyn.
Cheers Rob
Sorry - been too long, I'm afraid.
Jared
Quote from: Zxrob on September 14, 2025, 14:00Hi All.
Cheers Rob
I have some taken out of my car that worked fine before I changed them, I can dig them out and send you a pic of condition if you like
Zxrob
Quote from: Jared on September 15, 2025, 12:04I have some taken out of my car that worked fine before I changed them, I can dig them out and send you a pic of condition if you like
Yes please.
Cheers Rob
Craigjm
They are just standard 16.5 components and you will need a fitting ring set to fit aftermarket speakers. You can pay anything from £20 up to £1000s for a set. The stock wire is rubbish too so you really need to change that too. Are you planning on just keeping the standard head unit?
Zxrob
Hi Craig.
Think ill find a standard one for now.
Thanks anyway
Rob
Craigjm
Quote from: Zxrob on September 16, 2025, 21:25Hi Craig.
Thanks anyway
Rob
Where are you? I think I've got a couple in my garage. I'm in leamington spa
cptspaulding
Quote from: Craigjm on September 16, 2025, 00:32They are just standard 16.5 components and you will need a fitting ring set to fit aftermarket speakers. You can pay anything from £20 up to £1000s for a set. The stock wire is rubbish too so you really need to change that too. Are you planning on just keeping the standard head unit?
Many have used the original speakers as fitting rings. Remove, cut out the entire diaphram & use the frame that's left to mount your new speakers.
Craigjm
