Axle stand locations?
Started by chalced, October 22, 2025, 09:05
chalced
Need to do some underbody lanoguard spraying and was wondering where the best place is to put the axle stands to raise the car when I am under - bearing in mind I have a full body kit, so they can't go on the sills which would be the normal place. Ta
At the rear:  The mounting point of the arm trailing from the chassis to the hub.  At the front the rear mounting point of the A-arm.
chalced
