Rear Subframe
Started by valguss2001, February 11, 2026, 09:46
valguss2001
Hi Guys
Been trying to search around the forum and can't quite find a definitive answer to this. Can a PFL MR2 take a FL rear subframe?
Part numbers -
51206-17030 - PFL
51206-17040 - FL
2001 silver roadster called Mr Bug
99% yes.
The fl has fixing points for the revised suspension that wouldn't be used, whereas the pfl cannot be used on an fl, as lacks the fixing points.
That said, still best to get the correct one.
Craigjm
Facelift works on a pre facelift but not other way round
valguss2001
Thanks Guys
Think it's going to be almost impossible to get a PFL one unless it's 2nd hand, but can still get the FL one from Amayama.com. Going to try my local Toyota group as well now
Quote from: valguss2001 on February 12, 2026, 09:18Thanks Guys
Try Paul at TCB Performance...  also Midlands and East Coast often have very good used ones.
Craigjm
I got mine from GT4 play
@valguss2001
Try MR2 Ben currently offering PFL rear subframe :
New Subframe Genuine Toyota MR2 mk3 1.8L 1999-2007
Mounts under the rear engine, common for rusting away.
Available for:
Early 1999-2002
Facelift model 2003-2007
This is a New Genuine Toyota Part
Unsure which you need just give us a call and we will advise
Suitable For: mk3
Product Options
Year Choice: Early 1999-2002   £495.28
Year Choice: Facelift 2003-2007   £510.16
valguss2001
Thanks Guys
I've ended up getting a reconditioned one from JSpec
Tom
