Brake master cylinders
Started by moca2cv, February 26, 2026, 01:58
moca2cv
Does anyone know of a source for either new MCs or rebuild kits? I can only find LHD units new.
Has anyone fitted an alternative MC?
Want to avoid going down the pedal box route if I can. TIA
@moca2cv
A rudimentary search on the www lists as available via eBay at one end of the scale of price and MR2 Ben at £251 at the other end of the scale.
I would also try the guy in Somerset or down South there somewhere a one time affiliate  whose name I cannot remember , something like TCP !
moca2cv
Quote from: Joesson on February 26, 2026, 10:19@moca2cv
Thanks. You might be confusing with the clutch master. MR2 Ben sells a clutch master at £251 but not a brake master. EBay is all second hand. TCB, Amayama, PartSouq - all not available. I don't know if there's a magic stash of brand new MCs hidden somewhere, but damned if I can find it.
Quote from: moca2cv on February 26, 2026, 11:26Thanks. You might be confusing with the clutch master. MR2 Ben sells a clutch master at £251 but not a brake master. EBay is all second hand. TCB, Amayama, PartSouq - all not available. I don't know if there's a magic stash of brand new MCs hidden somewhere, but damned if I can find it.
I am very much confusing a clutch master with a brake master cylinder!
My specific search for brake master came up with a clutch master on MR2 Ben.
My search was more rudimentary than I intended. My apologies.
Have you spoken with the guy at TCB? He is usually helpful and may share some insight as to when or where the Master cylinder would be available.
https://www.fensport.co.uk/products/brake-master-cylinder-seal-repair-kit-ae86?_pos=21&_sid=4955a2f99&_ss=r
@moca2cv
Any good?
It came up after a search on the Fensport site.
Do sn't mention the MR2 mi 3 though.
moca2cv
Quote from: Joesson on February 26, 2026, 14:02https://www.fensport.co.uk/products/brake-master-cylinder-seal-repair-kit-ae86?_pos=21&_sid=4955a2f99&_ss=r
@moca2cv
Any good?
That kind of thing, yes, though that's for an AE86... I can't imagine they're the same. I think I need to find myself a spare unit and pull it apart and measure up. Perhaps there's something out there the right size...
