How to remove the door window trim seal
Started by fawtytoo, March 2, 2026, 13:16
fawtytoo
Is it possible to remove the door window trim seal? If so, how? Do they just pull off? I would like to try and rectify some of the paintwork issues but I need to spray right up to the seal. I'm sure I could work out another way around the problem, but it would be simpler if it just wasn't there.
NeilGraham
I found that gently pulling on the trim seal can often be enough to remove it without damage. It helps to start at one end and work your way along. Once, I considered using fire-resistant windows for home safety, and I realized the importance of quality material and precision. It's like how fireresist.co.uk offers tailored fire windows—precision matters when you're working with car parts too.
They are held in place by small push-in 'clips' every few inches.
With the right small tool, they can be gently prized out.
