Bump stop confusion
Started by househead, May 8, 2026, 14:19
househead
So, it just occurred to me that when I installed my suspension last week, I didn't trim any bump stops, and they were new bump stops from mr2-ben (bought nearly 6 years ago). I bought 4 of them, and they're all the same, and I've since learned the front and backs are different. I'm also confused about the orientation.
Wonder if someone can help.
First photo is a stock front strut with Tein spring that's come off my car (not installed by me). To the left of it is one of the four new bump stops I got with the plastic dust covers. These clearly are the same / almost the same. The writing is upside down, and the previous installer didn't trim these stops. This bump stop only mates with the plastic dust cover correctly when it's the other way around (with the writing on the bump stop right-way-up. Did the previous installer install these bump stops in the correct orientation, and should they have trimmed them? Or to put it another way, should I install mine in the same orientation, and should I trim it? Which side do I trim from and approx how much? (I'm thinking it should be installed with the writing correct-side up and with 20-30mm trimmed from the "bottom").
Next pic is a stock rear OEM bump stop taken from the struts I busted up to install Koni shocks. It's shown in the orientation I believe it was in on the car (fat side up). Should I use these OEM bump stops in my new rears (rather than one of the replacements I bought, that I now believe to be for the fronts)? Is the orientation correct (fat side up), and should I trim them at all?
Hopefully not to add to any confusion but my recollection is that the front bump stops appeared to need renewal  and this I did with new ones from Autodoc. The rears were pristine and so weren't replaced.
BUT, my recollection is that the front/ rear were different stops, it was a while ago and memory does not always serve well.
Quick edit won't work-
I trimmed neither front nor rear stops.
They need to be trimmed if the car is on lowering springs.
househead
Yea, I figured they're supposed to be trimmed when fitted with lowering springs, generally. The ones I took off the car (on Tein springs  -31mm rear, -35mm front) weren't trimmed. The ones I took off the donor struts (not sure which springs) I don't think had front bump stops on at all. Rears not trimmed.
Tein apparently changed their advice from trimming to not trimming. My instructions for the Eibach pro-kit going on ( -31mm front and back) are missing, can't find them online. Read too many conflicting accounts online too.
It's all very confusing. I think I'm going to follow Carolyn and do what makes sense which is to trim them front and back. Probably by about 0.8 of an inch. Not as much as the amount it's being lowered (as some suggest).
Starting to think once trimmed and on a lowered car that probably on the front the springs would bottom out of travel before hitting the bumper anyway?
fawtytoo
Quote from: Joesson on May  8, 2026, 17:21Quick edit won't work-
I'm wondering if you need to log out, then remove all cookies regarding this site and then log in again.
Quote from: fawtytoo on May  8, 2026, 20:55I'm wondering if you need to log out, then remove all cookies regarding this site and then log in again.
Thank you, I will give that a try.
It is very confusing! You end up having to go with your gut feeling.
I trimmed my front ones down at the thin end but did not trim the rear.
The downside of trimming the thin end is that you take off the softest part which would make them more progressive if left. I did trim this end to leave more "meat" in the stops though (hence the gut feeling!). If you dont trim the front, the car will be on the bumpstop most of the time which didnt seem right to me.
PS Mr2 Ben sell parts from other cars that they know fit the 2 but dont tell you that so they can look different!
Beachbum957
The Tein instruction recommends cutting the front bump stops .8 inch or 20 mm, and no change to the rear.  This is for OEM bump stops.  Yours do not appear OEM, but I would cut from the bottom of the stop as oriented in your pictures.  The OEM bump stop has a groove for the boot, and I cut just below the groove, which is closer to 1" (25 mm) removed.  I do not have the measurement after cutting.
We ran Tein springs for awhile and found if you don't cut the front stop, the shock is almost touching the stop with a static load, and almost any bump will be using the very stiff bump stop. It is fairly rare to hit the bump stop very hard after it has been cut.  This also works for other similar lowering springs like H&R.
househead
I've trimmed the fronts 20mm from the fat end, and I've installed them the other way up from the photo above. Does orientation matter? Can't see it mattering much ... the strength of the forces from each side might differ but it's getting squished (shrug).
The rears I have also trimmed a similar 20mm off the thinner end. One nobble. Orientation as per the photo above.
The Tein springs (being taken off) apparently lower the front by a further 4-5mm than the Eibach springs I am installing.
I have another set of unbattered stops for front and back so can always adapt in future. Will see how I get on with it for now. Thx for everybody's input, much appreciated as always.
Superluminal
@househead Off topic, but I'd be really interested to hear your back to back experiences of Tein Vs Eibach springs. I'm on Teins and an extra 5mm of clearance would make a massive difference to me.
househead
Quote from: Superluminal on May 10, 2026, 10:31@househead Off topic, but I'd be really interested to hear your back to back experiences of Tein Vs Eibach springs. I'm on Teins and an extra 5mm of clearance would make a massive difference to me.
Yea, that extra clearance but still being lowered from stock is what made me switch springs from the Teins that the car came with. Had a few issues grounding out and even had to replace one of the front support bars after it took a good bashing.
Will update here once I get a chance to test it out a bit.
Beachbum957
We went from Tein to H&R, and added a thicker front spring insulator.  The car is now almost exactly 1" (25 mm) lower than stock. The Tein were just too low.
