New Open source plug and play 1zz/2zz ecu using UAEfi, overdue upgrade Apexi PFC
Started by simonrobinson, June 3, 2026, 15:06
simonrobinson
Having battled with my ye'olde Apexi PFC on my turbo 1zz car I was at a crossroads. What I needed was a proper ecu that runs speed density with VE based tuning. The Apexi PFC has been good to get off the ground but its pretty terrible to tune and it has no closed loop wideband control and lots of other mission critical features that make a half modern ECU functional.
I already run an ECUMaster EMU Black on my other car, and I'm very familiar with all the standalones on the market. Something that has always bothered me is why is there no cost effective ECU on the market for the zzw30 - the MX5 guys are all over their low cost ecus, albeit it is simpler on an MX5 to implement due to Toyota has "Bean MPX" data that makes the cluster work on the MR2, thus I made the Bean Banger to make the ECUMaster work on my MR2 without all the silly piggy back dual ECU stuff.
Now I was introduced to an other open source ECU project by a fellow MR2 1zz turbo owner who is running speeduino - he suggested I looked into RusEFi who do an ecu board called UAEfi:-
https://wiki.rusefi.com/uaEFI/
So about easter this year I got into RusEfi, and make a very terrible prototype plug and play pcb that fits inside the MR2 ecu case, after some faffing about I am running that on my car as a daily driver and it works really really well, and its brilliant to tune.
There has been quite a bit of interest in this project, and its been tested to be very robust and reliable.... and it also integrates with the uaDash project which there is a bit about here:-
Now this is just a post to say there is a proper PCB in development now, another MR2 owner in the Netherlands has stepped forward who is a properly skilled PCB and electronics design engineer. I've given him all the stuff I've figured out, and he is working on making it a proper job!
So in a few months time there will be an ECU that will allow people to run either MAF or MAP, for their Throttle Bodies, Turbos, Superchargers etc etc and it will literally just plug in to the Mk3 MR2 and work. It supports 1zz and 2zz, and it has some clever features that makes wiring in lift solenoids, wideband, CAN, analogue inputs etc all very accessible.
Last weekend I have reverse engineered all the Aircon functionality, so it will support the factory aircon straight out the box.
To get one of these ECU's it should be about £350 roughly speaking, which should be a game changer, and there will be some base maps that support boosted 1zz, NA 2zz, Boosted 2zz and whatever else that grows with it.
Also this is not a commercial operation, there is no business here, this is an open source project that will be documented on Github which you can build yourself, but when I get PCB's made etc I will get 50 done in one hit as that is sensible and cost effective. This is a self tune system for people, there is no commercial support etc :) , this is not for profit, its for the love of MR2's! And the dream of there being more turbo cars out there  >:D  ;D
Is there anyone here who in interested in the project?
interested in the project? - Yes, in so far as I find it fascinating what you can do and have already done. Bravo!
But I would not be looking to buy and replace the oem tte kit, even if it came with the option of more ponies.
But I fully support the intent behind the project.
105e
Sounds good but way beyond my capability / understanding..
Bugster_MR2
Very cool. The MR2 community needs this.  8)
I am also a TTE turbo owner, and I would love to have a more modern ECU with new and modern capabilities.
Bugster
2001 red with KW3, TRD rear brace, Zero race cat and MAF-mod.
2003 silver TTE Turbo, underbrace, sidescoops, style bar, front bumper, rear spoiler, interior garnish, exhaust
moca2cv
I have a PFC sat on the shelf doing nothing, but I'd be very interested. Just a stock 1ZZ here but I have cams I'd like to put in sometime...
fawtytoo
simonrobinson
Quote from: fawtytoo on June  8, 2026, 15:04Can it handle an SMT?
No SMT will not be supported anytime soon sorry. We are actually using the spare middle connector (that is used on the SMT cars) as way to add extra connectivity for the wideband sensor, dash, sensors, custom outputs etc - thus if it were to support SMT it would take a full redevelopment of everything and the audience is so insanely tiny that it would be a poor investment of time. Sorry to disappoint you squire  ;)
simonrobinson
Just want to put a bit of an update out there as there has been radio silence.
Progress is being made, and there is now a proper bright guy on board who is a professional PCB designer and Toyota MR2 / Celica / Corolla owner and enthusiast.
There has been some little gremlins to solve, which are now solved and tried and tested. Its looking very promising!
This ECU will support:-
  • MAF / MAP / Alpha TPS blending strategies - So Boost and ITBS etc
  • Bean dashboard and factory Aircon functionality
  • Fully plug and play on the stock MR2 wiring
  • Onboard SDCard Datalogging
  • Onboard integrated Wideband and close loop fuel control
  • 3 x Auxiliary analogue inputs for custom sensors like oil temp etc
  • Output for Drive by wire throttle or electronic turbo actuator
  • Lift control on separate output pins so no cutting of MR2 harness on 2zz swap
  • CAN output and out the box support for the UADash monitor dash
  • Open Source design so anyone can manufacture batches forever!
Redjay
Strangely enough. I was asking google AI about options for engine management today  - should I ever get around to turbo-ing my MR2, and decided to stop by the forum to see what people are up to these days. When I bought my turbo kit it was supplied with on old e-manage blue...
Mark A
simonrobinson
Getting close to an actual proper manufacturable thing  ;D  ;D  ;D
Just uploaded this proper update video showing more about the plug and play ecu build and how they are tuned etc....
Soon there will be the first batch made, quite how many that will be I'm not sure but they will exist.
86demon
tatieu
I'm very interesting by this product !
What's interface du you use to upload your map into your ECU ?
Mark A
