Main Menu
Sparkies
Started by Ardent, June 6, 2026, 11:12
Having looked up when I fitted the rear calipers. I also noticed.
In Feb 2021 I fitted 4x iridium plugs. I'm thinking with 20,000 on them they would still have plenty of life in them. That said the recommendation is to change at 5 years.
Do they need changing or perhaps just undoing and then nip back up?
Open to suggestions.
I reckon they've still got years of life left in them.  Of course they want you to change them, that's how they sell you some more.
https://www.partsinmotion.co.uk/
Parts in Motion list various manufacturers rear calipers for your 2.
I bout KYB shocks and brake hoses from them. Shocks all fine , hoses two visibly different batches for the hoses. My OCD was soothed as they changed them with no problem.
My rear calipers I bought iirc from a distributor of a Scaninavian manufacturer CK or something similar) They came with a 5 year warranty and no problem in my ownership.
PS
On Ebay
A company is offering calipers with matching part numbers with 5 year warranty:
https://www.ebay.co.uk/itm/165154216707?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338690639&toolid=20006&customid=e87def9585d2161b496885b1a3c50112%7C%7C&_trkparms=ispr%3D1&amdata=enc%3A1shuBq1JST2WeHjrD0dxWlQ31&gclid=e87def9585d2161b496885b1a3c50112&loc_physical_ms=41155
Quote from: Ardent on June  6, 2026, 11:12Having looked up when I fitted the rear calipers. I also noticed.
My 2 had an OE Denso sensor when i sold the car last year. That sensor  was 23 years old. 60k+ miles. The life of such a sensor is not too different from a spark plug.
In days of old the spark plug recommendation was to remove, check colour and gap,  adjust as necessary give it a brush ( brass brush) and refit if all ok.
@Joesson
If I'm reading that right. That's 2 for less than I last paid for 1.  :o
But if changing every year....
Quote from: Joesson on June  6, 2026, 14:44https://www.ebay.co.uk/itm/165154216707?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338690639&toolid=20006&customid=e87def9585d2161b496885b1a3c50112%7C%7C&_trkparms=ispr%3D1&amdata=enc%3A1shuBq1JST2WeHjrD0dxWlQ31&gclid=e87def9585d2161b496885b1a3c50112&loc_physical_ms=41155
Great price but the same issue, they state 1999 2002.
Is there are difference or not?
We know there are difference in PFL FL cables. Is there a difference in calipers? Seems one area even this group of knowledgeable people have not 100% pinned down.
Reading on in the ad. OE numbers are shown that seemed to match  with those you posted.
They show all 4 part numbers that cover 99-02 and 02-05
The table above shows compatible across all years.
Brakes international is the only place I see that list diff parts for diff years.
So are they correct and everyone else wrong. Or they are wrong in the sense it is the same part but Mr T just changed the part number.
I am stepping away from that/this rabbit hole before it's too late.  ;D
Craigjm
The time recommendation on a spark plug is about them seizing and becoming impossible to remove. Your low mileage doesn't need a change they just need removing and reseating. They will last 60000 miles
